Results 1 to 10 of 10
    Detroit, MI
    416
    e-revo 2650 on 3s lipo?
    i have a mamba monster with a 2650kv monster motor and how fast will the 2650 on 3s compare to the 2200kv on 4s and am i at risk for damaging any thing electrical wise. i have a 3s 5000mah 25c traxxas pack . thanks
    May 2009
    Edmonton, Alberta
    3,663
    http://www.scriptasylum.com/rc_speed/top_speed.html
    check it out in here. not a science but it will give you an idea of what it will do.
    i want to think that battery wont push enough amps for the MMM but im not certain. 125 amps is basically the bare minimum recommended but i don't know what they do if they run under.
    Detroit, MI
    416
    what if i run two of them parrellal? that would double the mah to 10000
    May 2009
    Edmonton, Alberta
    3,663
    by the math (mah x C)/1000 that makes 250 amp but i don't know if that calculation is proper for parallel or not.
    Detroit, MI
    416
    hmmm maybe i should just buy some extra packs to be on the safe side lol
    but i know on the traxxas packs it says 125amp minimum and 250amp burst for 1 3s 5000
    May 2009
    Edmonton, Alberta
    3,663
    That just means they are a 25c (50c Burst) pack. Very common.
    kansas
    8,677
    one 3s 5000 mAh 25c correct
    Batts in series double the voltage:
    2x 2s 20c 5000mah = 4s 20c 5000mah
    Batts in parallel double the mah capacity:
    2x 2s 20c 5000mah = 2s 20c 10,000mah.
    You can run one 3s... it will be slow like turtle. I have read of guys using one battery for young
    (or newboobie) drivers.
    change the cell volts....& gearing
    Import this:
    Differential Ratio: 2.8461538461538463
    Transmission Ratio: 1.8333333333333333
    Other Ratio: 1
    Spur Tooth Count: 54
    Pinion Tooth Count: 21
    Total Voltage: 22.20
    Motor KV: 2200
    Tire Diameter (inches): 5.9
    Tire Ballooning (inches): 0
    Motor Current Draw: 0
    Motor Coil Resistance: 0.006
    Spur/Pinion Ratio: 3 : 1
    Total Ratio: 15.65385 : 1
    Tire Circumference (inches): 18.54 inches (470.8 mm)
    Rollout: 1.18:1
    Total Motor Speed: 48840 RPM
    Vehicle Speed: 54.76 mph (87.97 km/h)
    Effective KV Value: 2200
    KT constant: 0.61 oz-in/A
    W Monroe, Louisiana
    2,001
    2200kv*14.8= 32,560rpm
    2650kv*11.1= 29,415rpm
    So if you gear it up (to go faster) you should be getting decent track speeds (30-40mph).
    Its All relative to your perspective.
    Detroit, MI
    416
    Lol I am trying to soak it in guys, so I won't fry my esc
    ph yea thanks for the info
    South of St Louis
    6,368
    Yea higher math makes me dizzy.
