Results 1 to 7 of 7
    Jun 2011
    172
    Bottom motor bearing
    What is the size of the bottom bearing? Velineon 3500. Mine came out and rebuild kit didn't come with one.
    North Florida
    676
    you are talking about the bearings in the motor, right?
    it's the same bearing on both ends, 5x11x5
    the rebuild kit (p/n 3352) is suppose to come with both though
    fix, run, break, repeat
    Jun 2011
    172
    yes that is the kit i got, but my bottom bearing is smaller then whats in the kit. the bearing where the pinion is.
    Feb 2010
    Indianapolis
    14,174
    From my experience, the bearings are both the same size. Contact Traxxas and let them know your problem. They will take care of you!
    Jun 2011
    172
    By the paper, I have the current motor. So the bearing on the bottom goes on the inside? Then what goes on the outside? If anybody has a pictures...that would help.
    ok, the pinion side, does nothing go on the outside...in the little cut out?
    Davenport, Iowa Quad Cities
    2,471
    I've replaced those bearings with the kit. They should be the same size. My buddy actually poped the bearings out of mine since my hand has a tear in it. He replaced the bearings in one of the motors I've had sitting for over a year too. It isn't easy getting out but it can be done...
    Jun 2011
    172
    Quote Originally Posted by Dknuckles View Post
    Ya there is a bearing inside the can. I didn't see it cuz it was only the outside of the bearing. But I got it out, tested good thanks for the help
