Results 1 to 16 of 16
    5
    Slipper Clutch Gear Melting Destruction/Frustration...
    Hey guys its that time of year again when the n00bs come out with stupid questions so not wanting to disappoint here I am
    Anyhow I'm not a complete n00b I've had a few nitro cars in the past but to be fair this is my first Electric car.
    Anyhow long story short I got my ERBE last week and broke the clutch in per the instructions with the factory packs. Everything was perfect and operational as it should be. Slapped the 6S Lipo packs in and boom instant melted spur.
    The next day with a fresh rebuild AND tightening the slipper down to the level of the spring completely compressed and then backed off between 1/8th and 1/4 of a turn the car ran amazingly through about 1/2-2/3 of those packs but then proceeded to melt the spur again but this time also almost weld the flywheel to the pressure plate and ate part of the bearing and turned the race blue.
    Obviously I've got some heat/slip issues here even though I'm adjusted as tight as I can. I've read about people using Tmaxx brake discs in place of clutch pads (which makes sense) is this a plug and play/drop in solution? I don't need to drop $50 in parts every time I run this thing LOL I did search a bit but didn't find any definitive "yup it drops right in" type of posts.
    Any help is welcome and appreciated!
    Apr 2007
    Valrico, FL
    1,678
    Wow, that's pretty bad...can't you hear it slipping and feel the difference in torque getting to the wheels while your running? That's the "gauge" I use to adjust my clutch.
    When you get it replaced tighten that slipper all the way, not just untill the spring is compressed all the way but untill the slipper doesn't slip noticeably when you slam the throttle on a grippy surface, then back it off an 1/8 to 1/4 turn at a time untill it only slips for a second or two on hard starts, if it's slipping more than 3 or 4 seconds frequently it will burn up....that spring really does nothing on a brushless revo which is why there is so little difference in too tight and too loose on the nut adjustment...you were obviously still too loose with just the spring compressed and then you loosened it a little more. Look at it this way...when you slam the throttle back on 6s you are dumping 5 horse power onto that slipper clutch instantly, it's got to be tight not to slip and the adjustment window is very narrow.
    This is all assuming your slipper didn't have anything wrong with it to begin with of course. Go with the aluminum pads if you want something better than the stock fiber pads, although I think I heard it comes with the aluminum pads now?
    -ERBE
    -Slash 4x4
    5
    Admittedly the first set of gears/clutch setup (which was my first set on lipo) I thought I had another issue (acted like low voltage cutoff) until after running it for about two minutes realized what it was doing so that was definitely my fault. The second go around was with the slipper what I thought was pretty **** tight as I said with the spring completely compressed (and tightas well) and the backed off 1/4 turn on the aluminum pads. This thing got so hot that apparently it collapsed the pressure plate onto the flywheel in the center/bearing area.
    I picked up a Tmaxx brake disc today how are people attaching this to the flywheel just simply increasing the hole size? Is there a slipper setup out there that everyone pretty much agrees is bulletproof?
    Apr 2007
    Valrico, FL
    1,678
    Quote Originally Posted by GTPprix View Post
    I don't know what you need to do to make the brake pad work but the pad wasn't your problem anyway, your slipper was either too loose or damaged in some way and got waaaay too hot.
    -ERBE
    -Slash 4x4
    Springfield, MO
    3,679
    I'm impressed you can get it that hot... I know mine will start to fade if I get it too hot, do you just drive right through the fade until you get failure?
    Also the spur gear is melting... from the inside? Not the teeth right? Because if its the teeth, thats your gear mesh, and not the slipper.
    5
    Quote Originally Posted by ducati777 View Post
    LOL I go big or go home hehe The spur is melting from the inside/heat transfer to the gear in my case. Honestly on the second outing when things were working how I thought they should be the fade came on after about 20-25 minutes of running and the way it acted I figured I had drained the pack and simply hit the low voltage cut off. I drove it back to my driveway and coming up the driveway it gave out.
    I know the clutch isn't my problem but I'd like to upgrade it while I'm in there hence my questions on the Tmaxx brake disc and any sort of known "bulletproof" setup
    Springfield, MO
    3,679
    Wellllll..... have you got the aluminum or fiberous pads in it now?
    I'm glad to hear you're actually using the slipper. A lot of people just crank it down then complain about their diffs being short lived.
    You're not doing anything silly like running big joe tires and trying to go fast on 6s are you?
    5
    Aluminum its what my truck came with stock so I've continued using them. I figure the slipper is there for a reason the engineer in me knows that companies don't spend money or overcomplicate designs where they don't need to. Factory wheels/tires trying to go fast on concrete primarily (high load).
    Springfield, MO
    3,679
    Then you should be able to make the stock one last.... I got a little over a year out of my first one, still on my second.
    My pads finally wore to the point that the center of the slipper would contact, and relieve pressure making it slip more and more...
    I think Robinson makes a slipper that can hold 6 pads. I've never used it, as the stock one has worked fine for me. Which makes me think maybe something else is going on, because it sounds like you're building heat pretty fast.
    How about the bearings? If you move the motor so it doesn't mesh, does the truck roll really nicely?
    edit:
    Have you played with the torque control in the ESC software? Its a pretty easy way to reduce driveline stress, although it can make for some quirky low speed handling.
    Apr 2007
    Valrico, FL
    1,678
    It's made by hot racing actually...I run one with 6 aluminum pads and have been very happy with it.
    -ERBE
    -Slash 4x4
    5
    edit:
    I'll check the mesh tonight when I get home, I don't remember feeling anything odd when I was working on it but I might have missed it. Haven't played with ESC yet that may be the next thing I try if this next batch of parts ends badly LOL
    Anchorage, Alaska
    56
    Silly question, anyone have a video about setting the slipper? I think that would be really useful but I don't have a camera to do it. One that shows the gear mesh, then adjusting the slipper for the different conditions. Just an idea.
    Dec 2009
    Pa
    774
    Quote Originally Posted by candy76man View Post
    +1on the double up slipper. i have used that for over a year and it works like a dream with aluminium pads
    Revenge 1/8 buggy
    Apr 2010
    Newport, NC
    312
    Will the double slipper work on the slash 4x4?
    Sent from my iPad using Tapatalk HD
    Caution, this message contains words.
    Springfield, MO
    3,679
    Quote Originally Posted by KoolDeal View Post
    I doubt it, the Slash uses a smaller diameter slipper.
    Apr 2007
    Valrico, FL
    1,678
    It may be possible actually...I know people have put the stock erevo slipper clutch assembly in the slash so there's a good chance the hot racing one would fit as well, I don't think any of it's dimensions are greater than the stocker at least. I would search around and try to find someone who has done it successfully before dropping money on it though.
    -ERBE
    -Slash 4x4
