    Long island NY
    72
    Transmission gears
    I bought an older Stampede XL5 Is there a way to tell if the transmission has metal gears without taking it apart? it is the gray plastic case not black.
    Redmond, Wa
    330
    there should be a piece of tape on the bottom of the trans youll have to take the rear skid off and look pull up the tape and youll see if its metal gears or plastic
    Extended P2de and Mini Summit
    2,088
    If its a stock grey trans it has metal gears.
    RC Turnbuckle Jr. BaldyDaniels's Avatar
    Rouleau, aka "Dog River", Saskatchewan, Canada
    3,269
    Quote Originally Posted by jaman View Post
    Unless it's been messed with... Keep in mind this is an older used pede, so there could be any mixture of parts in there. Best to do as directed above and remove the rear skid plate, peel up the tape and see if the diff is steel. But even this won't give you a definate answer of what the other gears are made of. Plus, you don't know how well the last owner looked after it, so if I were you I'd take the tranny apart and inspect the innards and regrease.
    Sent from Dan's iPad using Tapatalk
    Never trust an "Atom", they make up everything.
    2,215
    Quote Originally Posted by BaldyDaniels View Post
    Exactly always make sure before you run!
    "I like rc cars"....."WHAT? YOU'RE KIDDING!"
