    San Jose, Costa Rica
    704
    Question What happen if...
    I run my slash when is raining or a wet area(like wet grass)?
    The manual say than my slash is waterproof, is really waterproof or i need to make modifications?
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
    May 2010
    Nova Scotia ,Canada
    1,246
    You should be fine. What battery are you using ?
    704
    NiMH Power Cell Series 3 #2940 with a parallel connector
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
    Riverton Utah
    5,584
    You should be fine running your slash in water. Just make sure if you do run in water alot to keep an eye on your bearings because the water will dry them out of oil. Everything on the slash is "waterproof" but the trannsmission can let water in over time on the seal in the front bottom of the cassing. Have fun running your slash in the water!
    Is owning 27 RC's too many? No way!
    South of St Louis
    6,368
    Your black screwsheads will rust over time.you can replace em with stainless screw off eBay.
    704
    ok thanks for the help
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
    2,215
    It is completely waterproof, but I would recommend putting a dab of grease on the underside of the little cap on the top of the aterproof reciever box. It helps keep the water out.
    "I like rc cars"....."WHAT? YOU'RE KIDDING!"
    RC Champion dgudenau's Avatar
    Michigan
    1,176
    Make sure after the run you completely dry the car and lube the bearings. I sprayed wd-40 on my screws to prevent rust.
    Anza Slash VXL
    Rustler VXL
    Vancouver, B.C. Canada
    255
    tape over the air holes in the tires if you get water in there it can be a real pain.
    Slash 2wd Vxl, ERBE; Crash N Learn
