Results 1 to 23 of 23
    Pomona CA.
    325
    No grip in skate park
    I took my slash to the skatepark and had no grip, so I need pavement tires , what kind?
    Traxxas Slash 2wd and Thunder Tiger Tomahawk Vx
    RC Champion dgudenau's Avatar
    Michigan
    1,176
    You could try some anachondas from traxxas or street fighters from proline
    Anza Slash VXL
    Rustler VXL
    Washington State
    625
    Not sure how grippy the SCT version of trenchers are but they're incredibly grippy in their 2.8 monster truck size.
    P2de VXL - Summit
    phoenix
    1,118
    any street tire should give you enough grip at the skate park. i might do the same thing.
    14,885
    The traxxas s1 tires from my platinum worked great on wood. They are softer than the normal tires. The one thing I like about them in this environment, is they absorb much more off axis landing punishment compared to all other sc rims because of the way that the outside bead is made.
    Ya can't polish fertilizer...
    North Central OH
    1,050
    You might loosen the slipper a bit in this environment too.
    South of St Louis
    6,368
    Are you driving on wood or concrete? My local skate park is all concrete. I usually get pretty good traction on my stockers.
    QLD, AUSTRALIA
    121
    metal ramps you have no chance you need suction cups on the wheels, move your suspension on the arm at the rear to the
    2nd hole out
    2,215
    Yep depends what the surface is. If its the real slippery smooth concrete that a lot of parks use then I don't think ANY kind of tire will give you much good grip.
    South of St Louis
    6,368
    I get better grip with my Pede and the talons but probably because the tire is wider, so you'd expect better traction.
    Pomona CA.
    325
    It is concrete, real slick
    2,215
    Quote Originally Posted by vchirinos View Post
    Hmmmm...I think regardless of what tires you run you're goiung to be slipping around a lot then.
    Planet Vegeta
    651
    i think it is the park and not your tires, what tires are you using?
    newfoundland
    193
    I use Trenchers on splitsix wheels @ a concrete skate park . Stock Talons on my pede . Both seem as good as you will get - that concrete is usually slick .
    Cedar Rapids,IA
    188
    Not to argue here but I get great traction at my local park with stock tires. We have metal ramps but I just make sure I'm up to speed when I hit them. We also have a concrete hip and bowl and I have no problem on them.
    The harder I bash, the more I can upgrade.
    phoenix
    1,118
    street tires will give you the best grip at the skate parks. proline makes the street fighters for short course wheels and if you want even more traction you can run some stampede wheels with 1/10 truck tires (cause they are wider) like the proline streetfighters, road rage, road hawg 2, and speed hawg. any of those street tires should give you more traction then any other off road tire.
    14,885
    Get some traction compound, soak them a little, ziplock them the night before getting all the air out, and mount them at the park. The stockers will work better than before. You could try that before spending money on a full set of tires. The traction compound will def help whatever tires you buy.
    Michigan
    185
    I just put a pair of Street Fighters from proline on my truck today and I was SHOCKED by the grip it had over stock tires. I couldnt spin the thing out!
    phoenix
    1,118
    nice. there you go. enjoy. get some videos. lol.
    South of St Louis
    6,368
    How about hard foam street tires? I get pretty good grip with them on the street.
    QLD, AUSTRALIA
    121
    Due to council regulations around Australia we are not allowed tire compounds chemicals like that kids play on grass etc and even cement and the parks if they get it in their mouth it can be a very bad thing. shread a peice of tire
    Slash, DynaStorm, Sakura S, MERV, E-firestorm
    14,885
    Do you have simple green cleaner? You can use that on the tires, and while it is not as good as the traction compounds, it does soften up the tires. You could also experiment with things you are allowed to use. Some of the traction compounds are environmentally friendly so you could check into that also.
    Vancouver, B.C. Canada
    255
    proline street fighters have worked well for me on just about all hard surfaces i have ran them on, proline badlands are also supprisingly grippy on all terains.
    Slash 2wd Vxl, ERBE; Crash N Learn
