Page 3 of 3 FirstFirst 123
Results 81 to 91 of 91
  1. #81
    South of St Louis
    6,368
    Quote Originally Posted by kwitty View Post
    So we are still talking about a 'sealed differential' discussion LOL!
    So only two choices so far, add an FLM diff to your existing stock Traxxas trans or.........do an entire upgrade to the new Proline Racing Trans with a 'sealed differential' FLM upgrade about $45, Proline upgrade about $100 but includes several other beneficial features.
    Thanks O.G. for letting this thread roll on..........
    No prob kwitty, but I somehow missed the updates til now... How is your FLM diff holding up?
  2. #82
    South of St Louis
    6,368
    Quote Originally Posted by wmckay96 View Post
    hey O.G. I ordered My FLM diff May 2nd and it finally arives September 6th! a hole summer of bashing wasted!! thats what i call service!!! Does any one else have a beef with FLM/
    Wow! Mine didn't take that long to arrive but up in an earlier post I complained about how long it took. Who did you order from? RC-Monster was slowwww.
    Mine took 30 days to arrive: Ordered April 29th and here it is May 29th.
  3. #83
    Dec 2009
    350
    Subscribing.
  4. #84
    South of St Louis
    6,368
    I'm going to open up my track slash transmission this weekend and give the FLM a good going over. I put new silicone fluid in it this summer, probably June 2012, and I'd like to see if any leaked out.
  5. #85
    RC Racer armorred_slash's Avatar
    frazeysburg ohio
    192
    wouldnt you want a little bit of leakage to lube the idler gears??
  6. #86
    Knoxville, TN
    592
    Quote Originally Posted by armorred_slash View Post
    The point of the diff fluid is to slow the gears inside the diff so if any leaks out and gets on your running gears its putting stress on your motor and slowing you down. So no you don't want it to leak out. But if you are running regular grease in it let it fly.
  7. #87
    14,901
    ^^^^ +1. The diff fluid swhould be isolated from the gear grease...
    Ya can't polish fertilizer...
  8. #88
    South of St Louis
    6,368
    That's right. The fluid I use in my differentials aren't the correct lube for the ring gear. The ring gear should have a thin coat of the black traxxas grease or any automotive lithium-based grease.
    Inside the diff I use bad horsie diff grease or silicone oil especially made for this application.
  9. #89
    frazeysburg ohio
    192
    ok thats what i was getting at i use lithium hi temp grease ok thanks
  10. #90
    South of St Louis
    6,368
    I'm putting my new HR sealed diff in my 2wd Pede and I had filled that diff with wheel bearing grease and it all slung out over the summer... my trans case is pretty much spattered with reddish grease. I'll post up some pics on my HR review (here) when I'm finished.
  11. #91
    frazeysburg ohio
    192
    sweet ill keep an eye on it
