Thread: Charging Times
    Quartz Hill, CA (High Desert, Mojave)
    78
    Charging Times
    Is there a magic formula or chart somewhere that shows charge times....
    Charge 5000mah Nimh by 4amp=Charge Time.....
    Something like that?
    I don't have a fancy charger yet (2.5amps Max)......
    and I don't want to wait around forever and would like
    44
    I have a 3000mah, I charge it at 4 amps and it takes about 50 minutes to fully charge. For a 5000mah charging at only 2.5 amps i'm sure it will take around 1.75 hours. If you can get a faster charger you could charge it at up to 5 amps but it will reduce your battery's life.
    West Chicagoland
    449
    Divide mAh by the charging amps will give you approx time. mAh stands for milliampere per hour so if you charge a 5000mAh at 5A it takes 1 hour.
    Examples:
    Charge 5000mAh at 4A = 1.25 hrs (1 hour 15 minutes)
    800mAh charged at 1.5A = 533 (.5 hours or 1/2 hour)
    RCtecUSA is right on, charging over 1A will reduce battery life.
    Rule of thumb charging at 1/2 your capacity is optimal for batt life but not punch, you should find a comfort zone for you and your batts
    RC Champion trax de max's Avatar
    1,945
    heres how to work it out.
    (5000mah / 4A) / 1000 = 1.25 x 60 = 75minutes
    (800mah / 1.5A) / 1000 = 0.533 x 60 = 32minutes
    capacity, divided by charging amps, divided by 1000, times by 60minutes.
    I think it works out right i only tried with these two examples.
    Google search trumps Wiki. Refer to user guide.
