Results 1 to 2 of 2
Thread: shock oil
    697
    shock oil
    how do you oil up your shocks. i know how to tighten the sping but how do you oil them. all help is appricated.
    12,485
    Remove the spring and collar. Unscrew the shock cap, remove the bladder and dump out the oil. Let it sit for a while till it all drains out, compress the piston a few times to help. Then lower the piston, fill it about 3/4 and then move the piston up and down to remove air bubbles, fill almost to the top and put the bladder and cap back on. If you over-filled it the excess will seep out of the weep hole in the cap.
