I suggest use a radiator(or something similar) because I dont think is very eficient use a bottle with ice cubes because every run you need to refill with more ice cubes and What happen if the water from the bottle is warm? There isnt a cooling system, you are using hot water for heat the motor. Just my suggestion
About the pump:
I am using a 12v pump and rigth now is working with just 6v( from the reciever)and is working perfect
For more info Please read all the thread![]()
Sl4sh MM2
T-Maxx 3.3
Summit 1/10
Sl2sh VXL
It's like the old lady that swallowed a spider to eat a fly.
Today I bought a Y connector for the waterpump and the radiator's fans, for use just one channel:
Pics:
Here is the part number: 2046
Sl4sh MM2
T-Maxx 3.3
Summit 1/10
Sl2sh VXL
Revived for the new people.![]()
Sl4sh MM2
T-Maxx 3.3
Summit 1/10
Sl2sh VXL
Keep it coming.
Ya can't polish fertilizer...
Ok. You'd better. Or else.I will....![]()
Might be better to do a setup like mine so you get direct battery power rather than taxing your esc so much.
I was reading some threads in others forums and I saw some Traxxas ESC with blown capacitors so I was thinking add an extra capacitor. (Like the people who have the spartan with the Castle Creations-Traxxas ESC Link here) for remove some stress to the stock capacitors...
Pics:
Also I made a homemade glitchbuster just for kill some time....I am going to post the pics later
Thanks for reading
Sl4sh MM2
T-Maxx 3.3
Summit 1/10
Sl2sh VXL
What is a Glitch Buster and what does it do?
"enjoy your ride"
Dennis
the glitch buster
it is pluged into the reciver and basicaly stors a small amount of power.
so when the stering servo truns or there is a high load going throught the reciver it lets the small amount of power go .
to minimize brown outs ,system shut offs
Which port on the receiver would you plug this glitch buster into?
"enjoy your ride"
Dennis
eny free port avalible
i think the all the reciver ports are in parellel sept for the signal leads
10/4, copy that... Now I understand....The capacitor helps/provide voltage stabilization if there is excessive voltage drop from the receiver when steering, using lights or other accessories etc from the bec so to minimize any brown out....Duh!!!!
Good idea at that... Had not heard to do that before....
I think I must of had a senior moment![]()
"enjoy your ride"
Dennis
Sorry for no answer the questions (I was very busy)
reod12x2: You are correct.
Orca44: Hope this helped answer your question.![]()
Sl4sh MM2
T-Maxx 3.3
Summit 1/10
Sl2sh VXL
I was thinking how to use my VXL ESC but with my modded chassis (I had to modify because of my MMM ESC) so I used zip ties but is a waste because I want use my MMM ESC and I need to cut them and then again zip tie my ESC...So I used velcro
Pics:
Also I found a capacitor....Perfect for a glitch buster:
Pics:
Size comparison:
Is an 47000uF capacitor....I want something bigger
That's for today
Thanks for reading![]()
Sl4sh MM2
T-Maxx 3.3
Summit 1/10
Sl2sh VXL
Thanks for posting this I tried to do this and it really works! The only thing I have to do is get the hot racing tranny.. Because of leaks.
That's cool! I would use that if I had it, you wouldn't believe how much mine heats up (mine is 4x4 though but I'm just browsing the forums) good job! I hope you can take it a step further and sell it as a kit or something!
Wow nice build!
Thanks!!
I suggest the HR gearbox because the consistent cooling with/without the water cooling system and cheap compared with others gearbox...
Thanks!!!... Lol Maybe I am going to make a patent for this and sell it
Thanks!!!
Remember... if you have any question let me know![]()
Sl4sh MM2
T-Maxx 3.3
Summit 1/10
Sl2sh VXL
i think its cool but it seems to me that you will not need it beacuse with the fans and the water pump runing all you have done is kill your run time. so if you run those you louse run time in turn the motor will not get as hot.lol but cool none the less.
...good idea, but is it worth doing?.....wouldn't putting a VXL fan on the esc and another fan with heatsink on the motor accomplish the same thing?...
This doesn't have any effect on the run time...
If you want to do something different to cool the engine, and have all the time and materials... It worth the time...
Here are some hobbyshops... (few but there are) and sell the Lipo the triple of the price....BUT I can buy LiPos online and they send it to here. Is called "Courier" and IT WORKS
.... I already have 2 2S 4500mah LiPos but I haven't the chance to test it because I tested the Lipos With the Mamba Monster and that "little" motor on 4s broke my diff ring because I forgot adjust the slipper clutch
Sl4sh MM2
T-Maxx 3.3
Summit 1/10
Sl2sh VXL
This is what the hobby is all about.... Doing your thing, and being creative... Not sitting watching TV, but MAKING something... Putting something together. I wouldnt do this myself, especially since I can get the 30 degrees in cooling from an all alum gearbox, but it is still a neat creation. Its alittle on the frankenstein side of thingsBut I think this could be a prototype for ya, and next round you could clean it up real good. Make it look nice.
But either way, keep doing your thing, and enjoy yourself.. Weight, cost, blah blah.. Point is your building something, and doing something creative. Your using your mind to get away from lifes daily grind.
on your fans, i would hook a y harness to the throttle channel then to the fans. not possitive that it would work, but if it did it wouldnt waste your batts. so far look ******* sweet dude!
wow traxxas. blocked f r i g g i n.
That is the way I live...Be creative and useful.
Thanks for the kind of words...
Thanks for the idea...I was thinking about a remote switch for turn on or off the fans and the waterpump...
Very strict filter...![]()
Sl4sh MM2
T-Maxx 3.3
Summit 1/10
Sl2sh VXL
Here are some pics of my Diff...
Sl4sh MM2
T-Maxx 3.3
Summit 1/10
Sl2sh VXL
They do tend not to run so good when like that they look.......
"enjoy your ride"
Dennis
Woh never seen that! Bet it made some noise in your gearbox
You ain't bashin unless your crashin!!
That sucks
15 dollars for a new one![]()
Loltrue...
Well....Yes and No
I was ruining With NiMh first and I Adjust the slipper clutch very tight because It was slipping a lot and the NiMHs doesn't have that punch like the LiPos, It start very slow and then it gain some speed....When the NiMHs died I tested the LiPos for the first time, fully charged and for see how much punch the Lipos has, I hit the throttle and it just fly (With the slipper clutch still tight because I forgot adjust it) and then it make a weird noise but then it finished, so I though it was ok but then after check the temp of the motor, I touch the throttle and the motor start to spin but the car didnt move at all...After that I think the slipper clutch was loose but I remember it was Tight and then I thought in the Diff....
yep...![]()
Sl4sh MM2
T-Maxx 3.3
Summit 1/10
Sl2sh VXL
