Results 1 to 10 of 10
Thread: Bearing sizes
    North Florida
    676
    Post Bearing sizes
    I'm putting a rolling chassis together out of all the extra parts I have, and I compiled a list of every bearing and their sizes so I could order them, and I figured I'd share if anyone needs a quick reference. Would be helpful if you might want to order upgraded bearings from somewhere.
    I realize this is all in the exploded views available from Traxxas, but this just might be easier than downloading every PDF and seeing what bearings go where, since the parts list PDF doesn't say what each bearing is
    NOTE - these are for a STOCK Slash 4x4; no oversized motor mount bearing or TechnoRC 6mm axle shaft brearings
    5x11x4
    2 front axle carrier outers, 4 rear axle carrier inners and outers, 1 for the slipper inside the spur gear (N/A if you have a center diff). 7 total
    10x15x4
    2 front axle carrier inners, 2 differential ring gear side bearings, 1 for the motor mount. 5 total
    8x16x5
    differential ring gear side bearings. 2 total
    5X8X2.5
    steering bellcrank bearings. 4 total
    6x12x4
    front diff pinion inner and outer. 2 total
    12x18x4
    rear diff pinion. 1 total
    And for kicks, if you need the teflon washers that go between the axle carrier outer bearings and the wheel hex pin, they're 5x8x0.5, 4 of them total, one at each wheel.
    Hope someone finds it useful
    fix, run, break, repeat
    26
    Thank you kind sir.
    Sweden
    408
    Rally
    Slash 4x4 Platinum x2
    Stampede 4x4 VXL
    Earth
    506
    Thank you! Makes things easier!
    Sent from my LGMS631 using Tapatalk
    Dec 2015
    87
    bookmarking this, thank you
    Oct 2018
    Great work, Thanks!
    Apr 2018
    Downriver,Michigan
    147
    Nice job digging this up
    I've been looking off and on for a listing for screw sizes.
    Jun 2018
    56
    Thanks for the sizes.
    Jan 2019
    94
    Very useful. Thank you.
    Mar 2018
    49
    Just to let u guys know, all bearings are 2rs, means all are rubber covered both sides
    ...except velineon 3500 motor...probably cuz of too much heat
    these are 5x11x4 2z 2x
    teknoRC carriers
    10x15x4 2rs inner 4x
    6x12x4 2rs outer 4x
    Hot Racing Motor mount
    10x19x5 2rs 1x
    Just to be clear (not sure if its worldwide) 2rs means rubber cover on both sides, as mentioned, 2z means metal cover on both sides
    Write a note with all bearing of your current rig will help a lot
