Results 1 to 2 of 2
    Pinion gear adjustment maxed out, spur gear eaten up.
    Has anyone else had any problems setting the gear mesh? My pinion gear decided to eat all of the teeth off of my spur gear so I bought a new spur and after installation I went to set my gear mesh and noticed that the slotted adjustment hole doesn't allow the motor to turn far enough to engage the gears so mesh ends up loose. I have the stock 14/68 gearing. Anyone else have an issue?
    Jul 2007
    Rc Room
    Dremel time! Make that slot longer if the motor isn't bottomed out already. Or run a larger pinion or spur.
