Page 9 of 17 FirstFirst ... 7891011 ... LastLast
Results 321 to 360 of 677
  1. #321
    7,264
    i've been working on it all day.....i took all the components from my REVO-E so that i can finish it, i'm tired now.....i think i'm getting sick, my throat feeling a little itchy.....better take some rest......on the other hand i got it to where i wanted it to be.
    to 87 GN; no issue with the motor fitting.
    Cameron; for as cheap as they are $15, this tires are'nt so bad at all, i might buy another set.
    here you go guys,
    clearance from the ground less than an inch,
    also received my XO-1 diffs and the only difference are the output shafts,
  2. #322
    Feb 2010
    champlin mn
    540
    Wow that looks great thats definately my next build
    Big Block KB
    ERBE Tekin rx8
    MERV Basher
  3. #323
    Vermont
    725
    nice job that's sweet looks great very clean! Can't say good job enough times
  4. #324
    3,338
    Well done mate......looking forward to seen the vid of the beast in action .
    Rock n Rolla !
  5. #325
    7,264
    thanks everyone..uploading video right now. i did'nt run it with the body on cause its not so stable, dont wanna take the chances of damaging it. seem like it need more support right around the wheel well, maybe some body post on each corner will do the trick.
  6. #326
    7,264
    heres a small running video clip. http://www.youtube.com/watch?v=1fKdIEb5HYI
  7. #327
    3,338
    Nice one mate...seems to be running fairly smooth from the video; how does it compare to the Revo-E??
    Rock n Rolla !
  8. #328
    kansas
    8,677
    ok I know why the zip ties on the rockers, but how much diff is it not tied..?
    OOooooo & nice fit the wheels in the wheel wells..
  9. #329
    7,264
    quick very stable and easy to control, suspension is a bit stiff thats because i have the summit springs on. i will put the stock slayer and see from there....if there is too much body roll then i'll get the silver/blue springs.
  10. #330
    7,264
    stands 1 1/2 inch, with the zip tie .75 icnh
  11. #331
    Mount Real, Canada
    628
    How fast it goes? What will be the name of the car?
  12. #332
    7,264
    not sure how fast it is,maybe 87 GN can figure this out for me....
    4s lipo
    gear mod1 36t spur 20t pinion
    2nd gear locked 38t, top gear 18t
    slayer FOC 33T/23T
  13. #333
    Dec 2009
    Buffalo, NY
    402
    Gear that thing to go 100mph. lol That thing is veary cool though.
  14. #334
    7,264
    6s will do....maybe. thanks Johnny
  15. #335
    kansas
    8,677
    not sure, you changed the gear ratio in the trans correct, not sure how that will work out....hummmm.. lets see....
    need tire size...OD...??
    Diff ratio
    4s = 40 mph
    5s = 50 mph
    6s = 60 mph
    change the cell count, spur & pinion count, & tire size.
    BrianG speed chart:
    http://www.scriptasylum.com/rc_speed/top_speed.html
    Copy / paste: Import this:
    Differential Ratio: 2.8461538461538463
    Transmission Ratio: 1.8333333333333333
    Other Ratio: 1
    Spur Tooth Count: 54
    Pinion Tooth Count: 21
    Total Voltage: 22.20
    Motor KV: 2200
    Tire Diameter (inches): 5.9
    Tire Ballooning (inches): 0
    Motor Current Draw: 0
    Motor Coil Resistance: 0.006
    Spur/Pinion Ratio: 3 : 1
    Total Ratio: 15.65385 : 1
    Tire Circumference (inches): 18.54 inches (470.8 mm)
    Rollout: 1.18:1
    Total Motor Speed: 48840 RPM
    Vehicle Speed: 54.76 mph (87.97 km/h)
    Effective KV Value: 2200
    KT constant: 0.61 oz-in/A
  16. #336
    7,264
  17. #337
    7,264
    Diff ratio
    4s = 40 mph
    5s = 50 mph
    6s = 60 mph
    BrianG speed chart:
    Other Ratio: 1
    Motor KV: 2200
    Rollout: 1.18:1
    tire size 3.8
  18. #338
    kansas
    8,677
    might be some what close 4s @ 4.10v is 43.43 mph...
    Looking a the vid, say pretty close 45 maybe 50 mph...
  19. #339
    7,264
    my guess were somewhere mid 40's too. i wish i can find a 34t spur thats plastic and not metal
  20. #340
    7,264
  21. #341
    kansas
    8,677
    I was going to tell you, don't ever run with out the body.
    "It is just a short run" next thing you know it is sliding down the street @ 40 mph......DOH...
  22. #342
    7,264
    yeah not onroad set-up, i was actually taking it easy on the first run, two of the passes are full throttle, the rest 50% to 75%.... with body on, it stay planted on the ground.
  23. #343
    7,264
    i change the summit springs with stock revo 3.3 springs green/red....its abit it the soft side....silver/blue probably the perfect one.
  24. #344
    3,338
    That's the combo I am going for...I'll wait for your feed back on the silver/blue. Its a pity we don't live in the same neighborhood...I have so many spring variations you could try .
    Rock n Rolla !
  25. #345
    7,264
    cheers mate, i dont mind you driving my RC.... for real, so as 87 GN.
    i've been trying to figure out on how to post my vid here without clicking it and take you to youtube site LOL. ???
  26. #346
    kansas
    8,677
    easy one tool bar^ happy face, link, Email, unlink, image, insert vid
    copy paste link into vid
  27. #347
    447
    don't know if anyone noticed...but on the first run...the run without the body...as the revo goes out into the background...a real 350Z comes rolling in....i was laffing my ahem off....ha ha...
    but yeah....very nice...i'm envious of ur ingenuity....**** u...how in the world am i ever gonna top that?
  28. #348
    447
    hot dayem...that body is just effing awesome...u have definitely outdone urself this time...a revo-e gt car....hot diggity dog dayem!!!! i want one real bad now!!!
    u need to race that X01 now...see if u can out duel that thing....i know it looks waaaaaay kewler than the X01...so u got that going for u....awesome work bud!!!!!!
  29. #349
    kansas
    8,677
    ^ good eye..how did I miss that...
  30. #350
    3,338
    Very cool mate .
    Rock n Rolla !
  31. #351
    7,264
    LOL yeah that was a girl driving that Z and she did'nt even see my RC heading towards her so i quickly turn around just to left her behind.
  32. #352
    7,264
    with only couple of run and my underside wheel well are all worn by the tire rubbing even with the protective gorilla tape. it flaps around and causes them to rub so what i did was cut 2 aluminum sheet and screw them both side just infront of the rear tires.
    heres what i'm talking about.
    now that i have this done, the body are much steady.
  33. #353
    7,264
    Quote Originally Posted by IvVaum View Post
    hot dayem...that body is just effing awesome...u have definitely outdone urself this time...a revo-e gt car....hot diggity dog dayem!!!! i want one real bad now!!!!
    send me the body and i'll cut, trim & paint it for you
  34. #354
    7,264
    no body around here that i know that own an XO-1.
  35. #355
    447
    u are truly inspiring...i love the fact that when u set out to do something....it gets done....i'm certain it translates to everything else too...
    love ur new mod to the side body...that is a first that i've seen...and i've always wondered about what and how people handle those sides...i've seen velcro...didn't like it...what u did...i like!
  36. #356
    7,264
    testing if i get this right
    [video=youtube;V7N7BO5j2_Wk]http://www.youtube.com/watch?v=V7N7BO5j2_Wk]&feature=g-upl[/tube]
    LOL i failed
  37. #357
    3,338
    LOL i failed
    Video mut have this before and after video [ ] and then insert link /video and agin before and after video [ ]
    hope that makes sense..
    Last edited by craig.mitch316; 11-03-2012 at 04:06 AM. Reason: battling to explain how to insert video
    Rock n Rolla !
  38. #358
    3,338
    Sorry mate...double post
    Rock n Rolla !
  39. #359
    7,264
    i was curious to see how much SlayVo GT-E weight cause everytime i pick it up it weight like a ton but when i put it on the scale..... this is what i got.
    9.0 LBs.
  40. #360
    4,871
    9lb is not bad considering its on Revo Chassis not the plastic is that with lipo and everything on it?
    help on posting vids: the video reel that is next to the picture post link that you have to use when posting pics to the right click that then copy the link that youtube gives you when you upload your vid, it gives it to me everytime and thats what i use to post vids with the video screen in posts.
    Living life.
