maybe my next vid will be drivers point of view. i just dont know how that will turn out though cause if i put the lid like a hat, the windshield is blury.
I love the body supports. I might have to steal that idea from you. I have noticed that's an issue as well.
i figure i put the support before the tires eat the body, got this idea from watching 5 scale onroad car
How much it cost for everything now? Any computation would be great.
i'm trying to find a smaller spur since i cant go any higher with my pinion, 20t pinion is the highest i can go, now finding a smaller spur is not easy to find and i did found one but its the steel 34T. anyone know where i can find a plastic one?
why can't you go up on the pinion??
i can probably give this spur a try
or what if i get the 34t XO-1 speed pinion and run it without the slipper clutch. i know that sounds bad but my trans are metal gears and i dont really gun from standing still so driveline is pretty much my issue there.
yeah mate....20t mod1. my tekno mount can only go up and down 6T difference.
heres my motor mount, this is my integy one,
side by side with the stock mount
here are my other 2 spur (40T/38T) along with 15T, 14T, 13T pinion
here is the size difference between mod1 and mod.8 pinion
left side 20T mod.8 other 3 are mod1 15T, 14T, 13T
20T mod.8 side by side with 20T mod1
i went ahead and order the HR 34T spur along with 22T pinion, i should get more speed with this. i know with 20t/36t gear....i dont have any heat issue so bumping up should'nt be a problem.
Sweet ride! Good job!
thanks 50. i'm thinking of maybe getting a higher KV motor so that i can put back my 2200kv on my REVO-E.
Give the leopard brand a try, last I seen they have some the same size as the 2200kv of 4274 in higher kv. Maybe 2400, 2650 I'm thinking about.
Living life.
Some of those look pretty good -how fast do you want to go!
80 plus..........![]()
There we go...80+.
Rock n Rolla !
even still, 2/3s it will be a good challange.............
change your radio to 70/30...
is changing it to 70/30 really make a big difference? do i have to reprogram the ESC to recognize the 70/30? i have'nt done switching 70/30 before though. i tried doing this with the VXL3s and i failed programing it so i just did'nt bother.
I was told you have too. You just have to recalibrate it and thats it.
yeah it was driving me nuts figuring it out and still cant do it lol.
me neither so i just leave it like that works fine for me on 50/50 doesnt hurt anything at all, if anything i would set my nitro to 70/30 as i dont need that much travel on the brake servo.
Living life.
i dont have a problem with 50/50 but if i can squeeze more speed by switching 70/30 then, by all means help me out here LOL.
yes you need to reprogram the ESC, gives you just a little more...........
Speed Control Programming Instructions
The Castle Creations Mamba Max speed control should not need
reprogramming with normal use. However, if you install a different
radio system in your model, or change the transmitter’s throttle-neutral
setting from 50/50 to 70/30, you will need to reprogram the speed
control. Follow these instructions to reprogram the speed control:
1. Install the batteries of your choice in the battery compartments and
plug the batteries into the speed control.
2. Switch on your transmitter.
3. Hold full throttle while you switch on the Mamba Monster controller.
After a few seconds, you will hear multiple tones and the
RED LED will light.
4. Hold full brake. After a few seconds, you will hear multiple tones
and the YELLOW LED will light.
5. Release the trigger to the neutral position. After a few seconds,
you will hear multiple tones and ALL THE LEDs will light.
It's simple. Post #7
http://traxxas.com/forums/showthread...=1#post5251811
____________________________________
Oop's 87 GN beat me to it. lol
so do i just slide it to 70/30 and reprogram from there?
yes..... make sure the truck is turned off.........tho..........
i got my HR hardened steel 34T spur in the mail today, put it on and gave it a test run and i lube it slightly just because lol.
http://www.youtube.com/watch?v=5RNqK9fPSTQ
i went ahead and order a spare wheels/tires set from suprasales, this time i got the white spoke wheels. for as cheap as they are...they actually hold up to speed. i for sure keep buying from him.
All I saw in that video were just various blurs...man I've never felt so cheated before in my life...was expecting something great...like perhaps a naked woman poping out or something like that...ha ha...
Looks like ur having way too much fun...keep up the good work bud!
i know this is way too early to mention guys but RCX expo is back again in Long Beach, CA in June 1 & 2 2013.........they said its going to be bigger, better than last year..cant waithttp://www.rcx.com/
wow...didn't even know that something like this exists...would love to go...but...oh well...when u go...take lots of pics and post them up here please...i'd like to see some of the kewl new stuff they've got out.
