Page 2 of 2 FirstFirst 12
Results 41 to 48 of 48
  1. #41
    Aug 2019
    So I found workaround:
    1. turn and pair everything
    2. run the app, update screen should appear
    3. dont run the update, just disable it by clicking on it and stay on the page in the app
    4. turn car of, wait unitl the car icon get red in the app
    5. turn car on while still on the update page
    6. the update page should refresh and tell, that there are no more updates
    7. Now there is the back button available in the app in the left top corner, that brings you back to the app.
    Note: you need to do this everytime you start the app....
  2. #42
    Jan 2015
    I went through hours of firmware update **** last night with the Traxxas Link app and TQi TSM receivers. I thought I had bricked 2 receivers. The app would link to bluetooth transmitter via my Samsung S9 phone on the latest updates for phone and app. It would see the TX and RX as connected / green in the app. When I went to the update screen, it would start updates on the RX, then fail after step 1 repeatedly, asking me to try again. Now both of my RX were showing firmware version 0.0.0 and I could not use the trucks, no controls. After searching many forum solutions, I found this is the necessary sequence with the latest Traxxas Link app (version 7.1.1.10624) and Android 9. - FYI I tried two tablest running older Android versions, and neither would even link bluetooth to the remote.
    1) install the latest app. You may want to uninstall any previous version, reboot device, then install new version.
    2a) Once the app is fully installed, don't run it yet!! If it's running in the background, close it.
    2b) Hold the app icon, then go into the app settings and allow access to bluetooth AND STORAGE.
    3) With the app completely closed / not running, switch your phone / device to Airplane mode (no radio communications)
    4) Turn on Bluetooth connection only!
    5) Launch the Traxxas Link app
    6) Turn on the TX and vehicle
    7) Link Bluetooth to the Transmitter/module
    8) Now you should be able to go into your app > Support > Updates and recognize the TX/RX/ESC properly.
    9) run the updates
    I hope this helps someone, and I hope Traxxas gets some better app developers to fix this to operate in a normal expected way without all these steps. With older versions (few years ago) I was able to just launch the app normally, and do the updates.
  3. #43
    Oct 2019
    I'm with Android. Enabling "Storage Access" to the Traxxas app solved my problems.
    Thanks jonUF02 for the hint.
  4. #44
    Nov 2019
    Updated my new TRX-4 yesterday. And I found this, for Iphone.
    Set the phone to Flight mode, only Bluethooth, that didn't work.
    But moving to another room in the house with no computers etc did the trick.
  5. #45
    Nov 2019
    Hi
    Ran into the blinking orange issue. The transmitter wont reset at all, no matter what. Continues to blink orange...so unable to proceed to the next steps. I ran the 1st tank for a break in process and got stuck when i tried to open the bluetooth on. Now unable to break in. Please advice.
  6. #46
    May 2019
    Michigan
    163
    Quote Originally Posted by jonUF02 View Post
    9) run the updates
    Thank you, this seems to be sorting out my e-revo's issues. Took a bit of poking around to find all the app/droid setting options and my desktop bluetooth settings but the Tx just updated and the Rx appears to be updating now as well. Both were well out of date, even b4 the Tx failed update bricked back to 0.0.0.
    edit ***, the VXL-6s ESC 'updating' step 2 of 2 seems have failed and be retrying..... up to retry #4.
    edit #2: turned off and unplugged everything and updated the esc again and this time it finished, no updates left. Throttle and Steering seem to work but for some reason I can't shut the esc off with the button, have to actually unplug a battery. The real test will be later today if it dries up some when I take it out for a test drive.
    Now to try and update my Rustler and Slasher and hope they don't fail, then finally finish the 4wd Slash Ultimate upgrade rebuild and get that thing updated also.
  7. #47
    Dec 2014
    Adirondacks
    1,393
    Quote Originally Posted by fozzy71 View Post
    ...for some reason I can't shut the esc off with the button, have to actually unplug a battery...
    That is part of the update.
    The EZ-Set button is no longer used to power off the model: to power down your model, simply unplug the battery, or batteries, from the speed control.
    https://traxxas.com/news/vxl6s-firmware-update
  8. #48
    May 2019
    Michigan
    163
    Ahh thanks for the info and link, good to know.
