Results 1 to 8 of 8
    Jun 2011
    Denmark
    19
    Grinding wheel hexes
    I keep grinding the wheel hexes.
    Both on the axles and on the wheelrims
    Anyone got an idea how to solve this issue?
    Sep 2010
    the giant boot. Anybody?
    2,726
    aluminium hex's and make sure you use loctite and tighten them all the way.
    Jun 2011
    Denmark
    19
    I already have the aluminium hexes, it just made the wear on the rims worse.
    I've used loctite and tried self-locking nuts, to no avail.
    Nov 2008
    Halifax County, Nova Scotia. Ca
    1,146
    I had the same problem.. Slipper adjustment will help.. Other than that.. 17mm adapters and buggy wheels or sc wheels from DE Racing have 17mm hexes..
    Sent from my highly abused iPhone using Tapatalk
    Always in Trouble for trying to help out.
    Jun 2011
    Denmark
    19
    Well I use the Center Diff, so adjusting the Slipper won't help much.
    I'll try the 17mm Hexes when I can find them in stock somewhere.
    Central NJ
    1,245
    The center differential is where your problem lies. If you loose traction it puts all the power to the front wheels making it hard to control. Replace that with the slipper clutch and get it adjusted right and you most likely wont have this problem anymore.
    Feb 2010
    13,186
    I was having that same problem on both of my trucks! One truck now has aluminum wheels and hex! The other I glued the aluminum hex into the wheels. When the glue is good and hard I remove the hex and is is custom form fitted. Both of these has to,ex my stripping problems.
    115
    Justin, the whole point of the center did is to increase control
