to see that this is not good!!!
I play til something breaks
ouch![]()
Wow, that's some good carnage you got there, what did you hit?!?![]()
nice !!!!!!
Good work, At least parts are cheap!
Sent from my DROID RAZR using Tapatalk 2
what's got me a bit confused is all the oil leaking. could it be from the shocks or the diff?
Ouch, don't worry, it happens to the best of us... I laughed when I read what you said, then when I read you sig... LOL.I hit a stupid curb full throttle on 3s. dumb move on my part.![]()
Judging from your pictures, I would say your shocks are leaking...what's got me a bit confused is all the oil leaking. could it be from the shocks or the diff?
Those are powerstrokes too arent they?
Everything overpowered...
Maybe you popped a shock cap off?
lol jacked up![]()
Cosmic bummer. But now you can go with aluminum at the corners.
Sent from Tapatalk version 3.14159265359
that is how you do it go big or go home hope you get it back together soon
I did the same thing to my left front this weekend. Hit a stair rail support at pretty high speed. Just broke off the A arm, no other damage to anything else.
surprisingly only broke the rear A arm which will be replaced with RPM and a front caster block. Any recommendations on an upgrade for that???
The shock that leaked was fine. just needed to refill it.
traxxas aluminum are great, strc are good, but need some dremel work to fit with mips
