Results 1 to 7 of 7
    272
    Whats everyone running for gearing?
    I was just wondering what everyone was running for gearing. I was thinking of going up a couple teeth on my pinion from stock to bring my power into the mid range. Any thoughts?
    12,314
    Gearing is different for everyone.
    Everyone has different terrain, driving habits, weather conditions, ect.
    The best way to figure out what gearing you need:
    Redmond, Wa
    330
    where should i start with gearing? i just built a summit from a parts bin i got its all stock and wiull be used for light bashing and light crawling where should i atleast start has stock pinion then i have a 23t spur or a 17t or 13t?
    Extended P2de and Mini Summit
    12,314
    Quote Originally Posted by cuda0872 View Post
    With a 23t spur it is going to be very hot.
    Stock for a Revo is 50t, I think the stock for a Summit is 55t.
    Start with a 17t pinion and a 55t spur.
    Use post #2 from there.
    Woodward, OK
    862
    I run an 18t pinion, gear on the motor. Stock is a 16t. You just have to watch your temps, if in heavy grass an 18t will make you run hot. I run pavement, short grass, and soft to hard dirt.
    Redmond, Wa
    330
    right on thanks guys i do have a temp gun so i should stay under 180 for the motor and 150 for the esc is this right?
    12,314
    Your hottest temps should be 180F for both ESC and motor.
