Results 1 to 15 of 15
Thread: Rough clicking
    Sep 2012
    38
    Rough clicking
    I've been running this slash vxl rough in bark chips and dirt and started noticing this rough sound when it runs, like a clicking/sticking noise. Only had this unit a couple weeks. And I'm a beginner.
    Can you tell what needs fixing?
    http://www.youtube.com/watch?v=sYzRSSjOh-c
    castalia ohio
    5,703
    oh yeah, just happened to me last night. you broke gears inside the transmission case. which one is hard to say but there are 3 main gears. theres the one on the end of the slipper clutch shaft, an idler gear, and then the differential gear. i broke ones on the differential gear and the idler myself.
    check this out
    http://traxxas.com/forums/showthread...bad-day-it-was..............
    Drag It!
    61
    That does sound internal vs something jammed in the drivetrain.
    Is your slipper tightened all the way down (the spring looks compressed fully)? Mine was from the factory...no slip. Does not allow slippage/cushion to the drivetrain.
    castalia ohio
    5,703
    maybe mine broke cus i did wheelies all the time? lol
    Drag It!
    Sep 2012
    38
    Found the broken gear, the differential, others look fine. Only stripped on one side....
    Pics here: http://imgur.com/a/yguOE
    Is there a gear I can replace this with which will be less likely to strip?
    Do you think the failure is related to the plastic transmission case? While this is disassembled I'm happy to replace any/all of these parts with high quality ones, including the transmission case, if it will reduce failure rate going forward. Appreciate your suggestions.
    Grassie Ontario Canada
    3,138
    That is you center diff and flm makes one ( Fast Lane Machine) its pretty expensive and I've never used one maybe somebody might be able to tell you how good it is...
    South of St Louis
    6,368
    Quote Originally Posted by kdvanb View Post
    It's fantastic, but $50 shipped. It's an all metal gear and case and can be sealed to hold different oil weights, usually 30000wt - 50000wt or higher.
    sent from my iPhone 5
    Hackettstown,NJ
    1,470
    Brian... that's too funny.. my sons slash just broke the same ring gear as well as the steel idler gear.. I've broken them in the past with my rustler and its mostly from the torque of the brushless motors and in his case, excessive wheelies... Its one of those things that happens, but thankfully not very often.. maybe once every year or so.. I looked at the FLM gear, but at $50 for that one or around $5 for the traxxas one.. I'll keep mine and my sons stock..
    Maxx3.3/ rusty5700/ slash3800/ slash5700 /4tec3.3
    46
    Quote Originally Posted by 08kgraves View Post
    How do you get your Slash to pull wheelies??? My slash keeps all 4 on the dirt! I have a Vxl but only running nimh batteries.
    Sep 2012
    38
    Hum.. Will think about the gear, thanks for the pointer. Maybe one of those "if it happens again" deals.
    While I've got this open should I put in fresh lube? What kind?
    castalia ohio
    5,703
    Quote Originally Posted by Bill6680 View Post
    im running lipo batteries lol
    Drag It!
    castalia ohio
    5,703
    Quote Originally Posted by brianfromoregon View Post
    well you have to replace the entire diff so the new one shouldnt have any fluid in it. you deffinately want some heavy diff lube so it will both stay in the unsealed diff longer, as well as keep one tire from spinning so much easier than the other.
    Drag It!
    castalia ohio
    5,703
    i think for the price of the flm setup for now that i will just buy extra gears, keep my slipper clutch a hair looser and run heavy diff oil that will stay in longer since mine is broke to. but i broke idler and diff.
    Drag It!
    South of St Louis
    6,368
    You'll need to go lipo for better wheelies, and keep the slipper backed off 1/4 turn from fully tight.
    castalia ohio
    5,703
    yup im running 2 cell lipo at 1/4 from tight and i cant keep the front end down lol
    Drag It!
