    Sep 2012
    stripped chasis screw question
    Ive had my p4de for two months and its the first rc car ive ever owned. The screw mounting the esc thats in between the esc and the steering servo seems to have stripped the chasis and is actually lost now. When I replace what do you do to keep in place. I assume its a common problem.
    Jul 2012
    Granger, In
    185
    Happened to me too. might get a slightly bigger screw. could use some sort of hobby grade glue or compound, I forget what it's called. I would imagine super glue would do just fine for that.
    South of St Louis
    6,368
    Try a longer screw with some blue loctite to grab some new deeper threads.
    sent from my iPhone 5
    Jul 2012
    Granger, In
    185
    Correct me if I am wrong, I thought loctite worked only on metal to metal.
    Aug 2012
    central nj
    51
    works on alot of materials,but just a longer screw will fix it
    Oct 2011
    Dirty Jerz
    264
    this happened to me also and a many others on this forum. Traxxas refuses to do anything about it other than sell you anew esc which is ridiculous. try a longer screw with a nut.
    I play til something breaks
    Aug 2012
    Saginaw,MI
    355
    i just put new longer screw in mine. sounds like yours is in the exact same spot as mine was. i hacksawed the bottom of screw off once the screw was in for good( the screw was way too long)
    RACE IT, BREAK IT, FIX IT, REPEAT!
    South of St Louis
    6,368
    Quote Originally Posted by mattstang2007 View Post
    Technically you're correct, but it will work on plastic. Loctite advises to use caution with plastic.
