Results 1 to 8 of 8
    LA
    415
    High reving after speed runs
    Is it normal for a jato to rev high after speed runs it runs pretty good has a nice trail of smoke and the hottest temp it gets to is 225 It only revs up a for like 4 seconds and then slows down to normal
    Nov 2003
    Long Island, NY
    2,602
    Is it possibly downshifting into 1st gear making it sound like it is reving higher?
    Rustler-3.3,Revo-Hyper .21,Jato-3.3
    lots of mods
    LA
    415
    Well it does it from a complete stop
    Nov 2003
    Long Island, NY
    2,602
    I thought it was right after the run as it was slowing down. Not sure what it could be.
    lots of mods
    LA
    415
    Yeah it will rev for a couple of seconds after i stop fast
    Oct 2005
    19,383
    Sounds like your LSN may be a bit lean...... Try using the pinch test to set the LSN.
    Pinch the fuel line 1-2" from the fuel inlet and count. Once pinched the engine should run for 3-4 seconds, the idle should rise as it stalls...
    Less than 3 seconds, richen the LSN, do a WOT pass and re-test.
    More than 4 seconds, lean the LSN, do a WOT pass and re-test.
    Then fine tune the HSN and then the idle screw. Always do a WOT pass in between adjustments. Always tune with 1/2 a tank...
    Hope this helps...
    All Lives Matter
    Minnesota
    303
    mine did that when it shifted from second to first.
    Philippians 4:13
    Red Deer, Alberta
    244
    Your LSN is to lean.
    Easy fix.... Turn LSN counterclockwise 1/8 turn until you notice its not "hanging" when you let off the gas. Also the engine might be running a little hot. Be sure to regulate fuel intake for proper cooling. Hope this helped.
    1.0 - Spider / Ball Python
    1.0 - Pastel, Het Orange Ghost / Ball Python
    0.1 - Pastel, Het Orange Ghost / Ball Python
    0.1 - German Shepherd (Kahlua)
    REVO 3.3
    HPI SAVAGE X 4.6 Big Block
    AXIAL AX10
