Page 1 of 2 12 LastLast
Results 1 to 40 of 41
    Aug 2012
    Central NJ
    1,245
    Cool TRCE with a little slash left
    Still a work in progress but nearing comlpetion.
    Sorry for the crappy phone pics but Ill get decent ones later when its done.
    Whats left of the slash are
    Front and rear differenatials and housings filled 10K/5K respectively
    Center differential gears, FLM housing filled 20k
    Body mounts (prolines are hanging on the wall until I get a new body ready)
    Traxxas aluminum shock towers (waiting for TRCE adjustable magnesium to be made)
    Well that pretty much covers it for traxxas parts.
    Motor/ESC progression
    Velineon, that was short lived
    Sidewinder SCT with 1410 motor....the ESC was short lived
    MMP/2400 combo worked great, a little noisey and some cogging
    MMM/2650 massive amounts of power but a lot of cogging and throttle goes from 0 to 20% no matter how you adjust the curves.
    Tekin RX8/T8 2650 Just put it in and did some trial runs doing laps in my basement LOL
    I think I have found home with this combo. Nice smooth accelertation that you can control and the curves will actually work on and compared to the Castle 2650 the noise is greatle reduced.
    RC Champion SLW-SVT's Avatar
    Lake Jackson, TX
    1,638
    Nice! The trce towers will complete the package but the Traxxas ones look good with the blue shocks. Are running extended arms?
    Sent from my iPhone 4S using Tapatalk
    X-Maxx Max6 | EB48.3 | ET48.3 | Axial Grave Digger
    Jul 2012
    Seminole, Florida
    439
    Looks good, are those integny shock towers? Please keep us updated on pics
    Lake Jackson, TX
    1,638
    Quote Originally Posted by JustinThyme View Post
    Aug 2012
    Central NJ
    1,245
    Yes its the extended kit from TRCE. Same specs at the proline protrac but made from magnesium with far more holes for options and any arm fits in any position. These also make short work of placing the rear shocks to the outside if desired as the holes are already there. Had the proline kit on it but kept having issues at the front hinge pins with the a arms breaking. The added stability this gives is awesome and gives about an inch increased trackwidth. To keep roar legal just have to run 0 offset wheels.
    The shock towers are Traxxas but not for long. The shocks are SC10 shocks and work great, better than proline powerstrokes and far better than the traxxas bigbore.
    Jason From TRCE emailed me today, they are about to cut some shock towers and should have those in a week or two.
    http://t-rce.com/shop.html#ecwid:cat...roduct=5421532
    A arms
    http://t-rce.com/shop.html#ecwid:cat...oduct=13479482
    Aug 2012
    Central NJ
    1,245
    Build parts so far
    TRCE chassis
    TRCE long arm kit
    SC10 shocks
    Tekno cvds front and rear
    TLM center diff case
    Savox 1258TG servo
    Lunsford punisher titanium turnbuckles and hinge pins
    Traxxas X-01 steering blocks
    Proline performance steering package
    Acer bearing kit
    Robinson racing spur and pinion
    Tekin RX8/T8 2650 combo
    Futaba R614FF RX
    Tonys screwz kit (way better hardened hardware that wont round out!)
    RPM F&R bumpers
    Tekno V3 mudguards
    Proline beadlocks for protrac suspension
    Proline Gladiators on it now M2. Worn down a little from trial runs on asphalt, they have nice traction/wear in the dirt but need a separate set for asphalt.
    All differentials rebuilt and filled F/C/R 10k/30k/5k
    Ive toyed with the receiver box trying the stampede receiver box on the bottom plate but it fits too tight with a motor/esc combo this large and made access to it a PITA for as much as I go screwing around with pulling the ESC wires to connect with a laptop and build profiles. It also doenst have enough room in it to bundle up excess wire and keep it inside instead of having it on the ourside flopping around. The most major reason of all it it places the RX directly next to the ESC increasing the risk of noise generated glitches. The top plate mount increases the distance by at least 3 fold. I will concede that the bottom plate mounted stampede box looks cleaner but sometimes we have to sacrifice looks for function.
    delaware
    936
    have you thought of trying a slash 2wd box i might have an xtra one i can send you to try if you want you have a nice truck there . what for batt are you running in the truck . and is that a race rig for you or a nice basher
    Aug 2012
    Central NJ
    1,245
    I tried the slash 2wd box still too tight, its actually larger than the the stampede box. The fact that Im running the T8 2650 motor and the RX8 doesnt excatly minumize space either. If I left a 550 can and a MMP it would fit, a bit tight but it will go in there. My problem is Im digging in the receiver box too much to get to the ESC throttle wires so I can connect with software. I wish someone would go to making an ESC with a built in USB port. The batteries Im running for the most part are Gens Ace 3s 5000mAh 40C. More than enough power and they fit this truck like a glove. Im racing and softcore bashing with it which really=no track close by so I have to do my trial runs and set up changes where I can. I have another slash 4x4 ultimate and slash 2wd for the hardcore bashing. Im actually thinking about turning the 2wd into an LCG with an Anza kit.
    Lake Jackson, TX
    1,638
    I put the full Anza kit on my Raptor and love it. I tried the slice and strc virst but didn't like them as much.
    Aug 2012
    Central NJ
    1,245
    Yeah I like the looks of the Anza chassis. Nice!
    Ive been eyeballing the Anza.
    I put the proline transmission in too. Love it with one exception, the idler is plastic. Take the metal idler out of the stock tranny and put it in the proline and waalah! Oil fill it and smooth as butter! One other plus is the area above the motor now has some access. I was able to trim down a castle fan and get it to fit. The 1410 and a MMP is whats bolted up in mine.
    Sep 2012
    Spirit Lake, Iowa
    76
    How well do you like the Tekin setup? Good power? Sensored? How big of LiPo can you run? I'm thinking about putting that in my Slash and I just want to know if it's worth the money?
    Aug 2012
    Central NJ
    1,245
    Great power, and yes its sensored (can be run sensorless if you want). It can run up to 6s but I dont see the need to go there (nor will the pack fit in my kit without some major mods). Im running 3s and its plenty fast enough. Speed calculator says 85mph on 3s and 23/50 gearing. I havent clocked it, GPS'd it or radared it. What I do know is it goes so darned fast that I back off the throttle well before I get out of radio range which with the Futaba 4Pks is around 1300ft and farther than I can still be able to see the car. I had the MMM/1512 2650 in it before this and it also was fast. My only problem with the Castle set up was lack of smoothness and more importantly lack of throttle control at lower RPMs. No matter how I set it up and what throttle curves I loaded on the ESC and the radio there was no easy starting. It was like 0-20%. Ease on the throttle very slowly and it would cross a threshold point then lurch forward. Its also A LOT quieter, no high pitch whining from the ESC and absolutely no cogging. As for cost, Amain lists the Castle MMM/1512 2650 and the Tekin RX8/T8 2650 at exactly the same price. Best deal I found though was at Stormer Hobbies, $50 less but they do charge a minimum of $7.95 for shipping ground. I bumped it up to second day air for $19.95 and still saved $30 over anywhere else. The Tekin is nice and smooth throughout the throttle range, ease on the throttle and it takes off nice and slow if you want it to and is nice and quiet. The only thing I can hear is the pinion/spur gears which isnt that loud either even though I have hardened steel on both, a little dry graphite for lube on the gears.
    Edit: forgot to mention, No BEC needed for the RX8 and an upgraded servo. Both the MMP and MMM have a weak internal BEC and as soon as I added a Savox 1258TG to it every time I would apply steering the whole thing would black out and the esc would restart. Had to add a castle 10amp BEC to it for it to work, glitch buster made it to where it would still glitch like crazy and not have a black out but still not acceptable.
    Aug 2012
    Central NJ
    1,245
    OK some updated pics that are actually decent instead of the camera phone.
    Took these with my Canon 1D MKIV and 24-70 f2.8L lens. I run a side business, professional photography.
    The only ting left before I am finished with this build is replacing the Traxxas aluminum shock towers with the TRCE adjustable towers that Im still waiting for. I have a Pro-Line Flo-Tek Ford F-150 Raptor body that I have all washed up and ready to paint but Im still comtemplating a paint scheme. Im quite proficient with an airbursh but having never painted detailed schemes in reverse I think Im going to go with a simple design until I get come clear transparacies to practice on. Its a bit of a different technique when you have to paint from the inside.
    Aug 2012
    Central NJ
    1,245
    Pics contd
    Atlanta
    996
    So jealous.... Looks fantastic!
    Aug 2012
    Central NJ
    1,245
    Thanks
    One other thing I am going to try is the Hot Bodies DB big bore shocks. Hooked up the other day and found a set and they will be here some time this week. I like the SC10 Bigbores but hey, gotta try everything!
    Also pulled the Savox servo, its too noisey for my tastes and went with a Hi-Tech High torque. Looks better and performs better and is much quieter.
    Just put fresh rubber on too. Proline street fighters on renegade protrac beadlocks. They havent hit the pavement yet.
    Atlanta
    996
    Hey, just noticed the velcro battery strap in your pic. Which one did you use? I might try velcro instead...
    Aug 2012
    Central NJ
    1,245
    The velcro strap is off of a Losi battery tray, actually took both of them to stretch from end to end. I left the existing part in tact, used larger lock nuts, doubled over the strap and drilled a hole through it and placed it over the shaft. I then used a flat washer followed by rubber compression bushings then torqued the larger nuts down on the bushings compressing them so it spreads out the load instead of just the post and the nut holding it and keeps any sharp edges out of contact with the strap so it wont cut into it. Sorry for the crappy phone pic but i just went to my basement man cave and snapped and uploaded it real quick to show you the detail.
    The stock TRCE hold down is awesome, just too much of a PITA to have to carry a tool for battery change outs. Im running primarily Gens Ace 3s 5000mAh 40C hardpacks and they fit in there like they were made for eachother.
    Aug 2012
    Alberta Canada
    1,071
    Are your shocks stock SC10? I need some new ones for mine, is the RR spur/pinion noisy? i'm getting sick of eating spurs with dirt getting trapped, I may have to get an open design chassis.
    Lake Jackson, TX
    1,638
    looks great man! I like the rear mounted shock setup, and I like the way it makes the truck handle..plus it's more buggy like!
    cycon...just get the ssc battery straps! they are only 15 bucks!
    Florida
    360
    How does your 4x4 handle on the track or have only tested it on the street?
    Thanks
    D8 shocks are great cause my 4x4 doesn't bottom out on big jumps. IMO, the only bad thing about them is my 4x4 feels heavier and I lose cornering speed; I never actually done any quantitative analysis to prove both of these theory, itís just my opinion based on feel and how the rc handles.
    Superman don't need no seatbelt-Ali
    2x SSC SL4x4
    Sep 2012
    156
    Awesome looking 4x4 and great pictures as well. Nice job.
    Aug 2012
    Central NJ
    1,245
    Quote Originally Posted by Maxx_Adam View Post
    Yes those are SC10 shocks. The RR hardened spur and pinion create no more noise than steel on plastic when meshed correctly and lubed with dry graphite.
    Quote Originally Posted by DriveItLikeYaStoleIT View Post
    D8 shocks are great cause my 4x4 doesn't bottom out on big jumps. IMO, the only bad thing about them is my 4x4 feels heavier and I lose cornering speed; I never actually done any quantitative analysis to prove both of these theory, it’s just my opinion based on feel and how the rc handles.
    It handles great on the track, no worries of body roll at all. Powers into and out of corners like a dream. Nearly impossible to roll over especially after adding the long arms. There is no comparison to the stock chassis, just not in the same league. I just got the D8 shocks today and going to try them out. Im figuring on having to use a different position on the towers and arms to compensate for the added stiffness but keep in mind I dont run the stabilizers that IMO add more stiffness than the D8 shocks. Its going to be awhile before I can get on a dirt track again to test it out. All I have to run on now until spring are asphalt ovals and one asphalt short course then wont have that after the first snow. I may very well wait until I get my TRCE adjustable towers before installing the D8 shocks so I can dial those puppies right in.
    Aug 2012
    Central NJ
    1,245
    Got some new goodies in today.
    Integy set up station
    FLM aluminum diff housings
    Revo diff gears
    Hot bodies D8 big bore stand offs
    Second set of gray springs for D8 big bores
    First impression of the D8 shocks left me less than impressed. I was liking the SC10s better.
    I installed the D8 standoffs (shorter than the traxxas and made for the D8s) and put the rears back in front of the A Arms, gray springs all around, dropped the weight of the oil to 30wt stood the rears up a notch and after adjusting for droop and putting it on the set up station and finding out my eyeballing isnt as good as it used to be....They are working great. Im sure I will fiddle with the some more but for now they are working more like I expected.
    Installed Aluminum diff housings with Erevo gears and found out that they are just a little different. The gears are all the same but the outdive shafts are not tapered down so I had to use the stock ones for that, have to check with Matt at Tekno to see of they make cups in that size.
    New body is mostly painted, one last step of airbrushed faux carbon fiber to do then its done.
    Still waiting on the TRCE shcok towers. They are running behind cutting them and once I have those in Im about all upgraded out. Looking for an Erevo roller to start on next but not having much luck. Either they dont want to sell just the roller or they think the roller is priced the same as gold.
    Sep 2012
    9
    Hi,
    Like your Slash! What droop are you aiming for F/R? Ride height F/R?
    /Daniel
    Aug 2012
    Central NJ
    1,245
    Quote Originally Posted by pd_jansson View Post
    Hi,
    /Daniel
    Thanks
    Droop at 16mm, ride height at 21mm both front and rear. I didnt do the trial and error on this, I cheated and got the inside scoop from Jason at TRCE. Who better than the manucaturer of the chassis that runs it like crazy.
    Sep 2012
    9
    Thanks
    I
    Hi,
    Thanks, I have to change my droop. I modified the upper mounts to increase the droop but I think I have to much now (22mm), especially for the indoor season. I will aim for 16 mm or maybe slightly less.
    I like your welcro solution for the battery, I have the welcro mounted the same way but don`t have the nice fastening thing in the middle.
    /Daniel
    Aug 2012
    Central NJ
    1,245
    I
    Hi,
    /Daniel
    The Velcro was both pieces from a losi battery tray. One wasnt long enough to go front to back. The front one was cut so I got the ring where I wanted it then the back on was the other end trimmed to where it overlapped just enough to fasten with a 3s in it. A 4s isnt going to fit in there but the Gens Ace 3s 5000mAh 40C fits it like a glove. Have to slide it in from the side just right but it goes in and is really nice and snug.
    Aug 2012
    Central NJ
    1,245
    Finished proline flotek Ford Raptor Body.
    Still undecided if Im going to put the headlight stickers on or not. Kinda like it without them.
    Obligatory crappy phone pics.
    Ill get some better ones later outside instead of on the breakfast nook table.
    Looks decent but not totally happy with the outcome. Im a bit on the picky side and want perfection.
    The Faux carbon fiber isnt quite as nice as I wanted. Learned from it though and know what to do next time to make it better.
    The metal flake in the blue didnt lay right in a few places either. I know what caused that too, adhesion promotor so I wont be using that again either.
    Beadlock rings are the stock proline black ones scuffed up and painted with the same paint as the body.
    Aug 2012
    Central NJ
    1,245
    No comments on my crappy paint job?
    Doesnt really matter anyhow. This was the shortest lived body in the history of RC.
    First run on the asphalt its now trashed, less than 15 minutes of run time.
    I hit a small jump and my bad for letting off the throttle too soon. Nose dived and cartwheeled at 30mph. The bumpers only got a little scratched up but it landed on the roof eventually and was spinning like a top. That scratched the roof a bit but not the bad part. Behind the right front fender the body cracked, not even a point of impact. I cant make heads of tails of why it did that, first body I have had that cracked. The scratches are just part of the game but Im a bit PO'd about the crack.
    Auckland, New Zealand
    27
    So you still think the D8's were a good buy then? Good for bashing you reckon?
    Aug 2012
    Central NJ
    1,245
    The Jury is still out on the D8 shocks. They are working better after some fiddling with positions, springs and oil weight but Im honestly still liking the SC10 big bores better. They look cool and all but Im thinking they are just too much shock for this application. I dont think you would have to worry about bottoming out on jumps but the loss of control in the steering dept is whats bothering me. With the SC10s setup correctly body roll wasnt an issue even when cranking hard on the steering at high speeds. Worst it would do was spin around. With the D8s yesterday even after tweaking quite a bit I about rolled it and had to drop the throttle quick to set it back down. Im already 3 holes out from center on the A arms and at this point I dont think Im going to get good steering response and good reaction on jumps and bumps. Im going to continue to try though just because I can. If I had a race tomorrow I would put the SC10 bigbores back on.
  33. #33
    Oct 2012
    4
    Justin I noticed you had the tekno axles, do they work with the trce long arms? Just wanted to know before i spend 80 bucks on them
  34. #34
    Bedford TX
    184
    Quote Originally Posted by jwtraxxas View Post
    Yes they do
    Rally GT8 4x4 in progress.
    FLM Rustler
  35. #35
    Oct 2012
    4
    Ok thanks i might pick up some
  36. #36
    Aug 2012
    Central NJ
    1,245
    Just make sure you get the right ones. For the TRCE long arm its the same specs as the protrac kit so get the Teknos for protrac.
  37. #37
    Lake Jackson, TX
    1,638
    well it looks like we're twins on the outside...my body def won't be as fancy as yours. I have the same beadlocks but they have calibers on them. How do you think the proline bodymounts will hold up? I just put them on too
  38. #38
    Aug 2012
    Central NJ
    1,245
    Well your body is still intact. Posted above how mine had the shortest life in RC history. It cracked right behind the right front wheel and spidered out. During the same run I managed to lose one of the caps for the proline mount, post screw and all but that was probably my fault. Must have not run the post screw in far enough. I thought it snapped off at first but its just plain gone! Had to order a new set of screw and caps but probably should have done that in the first place.
    I picked up a desert rat body that looks like it will be easier to paint and my LHS had a good price on it (only body he had for a slash 4x4). The flotek ford has a lot of bumps and ridges and details that were a PITA to mask off, especially the rear. Several days of prep and painted most of it in a single afternoon. I was a bit PO'd after spending so much time on the body for it to be trashed in 15 minutes. The scratches are all part of the deal of actually running an RC but the crack really got to me. Nothing hit anything or even close to where it spidered out. I spent hours meticulously trimming the body for perfect lines all around.
  39. #39
    Oct 2012
    Bay Area, CA
    51
    So with extended arms, how wide is the truck from the outside of the front and left tires (in inches)? Thanks!
    Nice looking Slash by the way! Sucks to hear about the body. I usually rattle can mine one or two colors because it is frustrating to spend so much effort/time on a body only to have it wasted away in a weekend at the races.
    Formerly Wildjones before forum upgrade
  40. #40
    Aug 2012
    Central NJ
    1,245
    The wheel track is increased by 1 inch over stock and the 0 offset wheels put it right back to the proper width as stock wheels have a 1/2" offset so its race legal. You can still run other wheels if you want, just have to watch your body mount so the body doesnt hit the wheels on max compression.
    I dont mind taking the extra time painting as with the LCG and and long arms I dont roll it, havent in a very long time. The mishap I had was from letting off the throttle right at the peak of a jump and nose diving it which sent it into a cartwheel. First time I have done that in awhile too. I guess I just got Murphy's law on that one cause I guarantee that would not have happened if I had anything other than a brand new body with fresh airbrushed paint. Before that the only "wreck" Ive had over the past two years or so is when my 10 YO son thogught it would be funny to ambush me on a straight away and pull out right as I got close and going around 40mph and Tboned his truck. He got a stern talking to on that one and its also when his broken stuff started going on HIS tab, not mine.
