    16
    Changing from 20% to 33% nitro fuel.
    I would like to switch from 20% to 33% nitro fuel in my 2.5 Rustler and wanted to know if there are any risks to my engine.
    I will re tune for the new fuel.
    Delta, Pa.
    1,888
    Always pose the risk of blowing a engine. Take it easy at first and allow the engine to break in to the new fuel.
    5,613
    Make sure you take all of the old 20% fuel from your tank when you go to put 30% in, other wise it will mix, and screw up your tuning for that tank of gas...
    Woodward, OK
    859
    You will of course have to retune. With 33% the window is smaller for good tune, but you can make more power, and run cooler. If your rusty is stock you may look into the slash drive shafts. Once I went to 33% I could not make a full tank with out popping the u-joint out of the shaft.
    Delta, Pa.
    1,888
    I would even consider some steel shafts.
