Results 1 to 7 of 7
    196
    Spur gear choice
    So I'm changing over to 32pitch gears for my stampede but can't seem to find any online so if you know a site please let me know and what brands are good
    South of St Louis
    6,368
    Use a jato spur and traxxas mod .8 pinions, starting at 14t or15t. I can post up the stk #'s later when I'm at my pc.
    Use all the other stock parts except the cover, you won't need it.
    South of St Louis
    6,368
    Buy one 32p Jato spur TRA3956, and matching mod 0.8 pinions: 12t TRA3942, 13t TRA3943, 14t TRA3944, 15t TRA3945, or 16t TRA3946. You can also order smaller or larger mod 0.8 pinions as needed.
    196
    Thanks for the info I ordered 3 jato spur gears from tower and 3 pions that weren't traxxas just 32 pitch I hope they work
    South of St Louis
    6,368
    As long as the hole for the shaft is the correct size they should work. Traxxas and Robinson racing make good pinions.
    7,176
    Quote Originally Posted by Chrisfoster View Post
    Running the VXL 3500 brushless?
    You are good to go if you ordered the 3mm pinions. Typically stated as Emaxx pinions.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    196
    No I orders 5 mm because the tacon motor has a 5 mm shaft but now I might get some for the emaxx too
