installing temp sensor
anyone help me out on where the two plugs go for the temp sensor and does it go around the cylinder. thanks
Temp sensor plugs into rx port that says temp/volt
If u have a power tap, that one plugs to the one u just plugged(red tab) if correct
Then use the the temp mount to mount ur temp sensor
do you just wrap it around the cylinder. thanks for the help.
Yes! and there's an accessory for it... Look for #6535...
http://buy.traxxas.com/product_info....oducts_id=9897
Thank you everyone, help hooking up voltage wire got the red tored, anyone tell me where the big black plug goes.
On the reciever should be s port for temp/volt
Rob
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
