Results 1 to 40 of 40
    Slovenia
    322
    7151x driveshafts stupid design ?
    I was ''pleasantly'' surprised when I got the 7151x driveshafts and realize that I must take apart whole vehicle including the diffs in order to install them.
    Why can`t they be made like center driveshaft (7250r) with bolt-on drivecup?
    It would then require removing just a few screws to install them.
    Feb 2002
    9,352
    why is it a stupid design? due to the cups, it wouldnt be able to have removeable youkes, and still have the dogbones
    look at other vehicles that use dogbones, their cups are part of the diff, not a piece you add on later
    Slovenia
    322
    Stock drive-shafts are mounted this way, aren't they? `....Can`t see the reason why steel-cups can`t be.... .
    I`m just presuming that you can replace the drive-cup with the bolt-on cup from the center drive-shaft ....
    Jun 2004
    1,894
    Companies still make shafts that have removable yokes, they just use a long screw pin like the stock plastic shafts use or a set screw on each side. MIP makes their shafts this way.
    ***You Build It ...I'll Jump It!!!*** OS .18 TZ; Trinity Pipe; HCR Titanium Skid Plates & Bumpers; Futaba S9450 Throttle Servo; Airtronics 94358Z Steering Servo; RPM A-arms & Knuckles; FOC; Lunsford Titanium Hinge Pins,Turnbuckles, Push Rods & Rocker Posts; New Era Roll Bar & Engine Mount; Proline Mashers on Velocity Rims.
    Feb 2002
    9,352
    mips are much different, they are a completely different thing, that doesnt use cups/dogbones.... they actually use a joint
    Slovenia
    322
    Yes but, they are mounted on the axle with a pin, same as cups on center-shaft.
    Somebody that owns both should check it......
    I`m just saying that Traxxas could make drive-shafts that can be installed without taking the whole car apart
    so cal
    9,244
    Maybe it needs more support because of movement of the arms. Different loads at different angles. The 7250r is set doesn't move up and down
    Feb 2002
    9,352
    exactly, the problem with those is they would go halfway to the axle, not allowing movement of the suspension travel....
    Jun 2010
    Miami, Fl
    6,731
    I agree with mtc777 traxxas should redesign them, like the CVD's for the big erevo, they need just a pin.
    Jun 2004
    1,894
    Not all of them...MIP has a lot of CVDs, with the dogbone style end on the diff.
    Feb 2002
    9,352
    Quote Originally Posted by airmaxx23 View Post
    i am not saying that they dont make them, but that on the mini revo, a huge cup liek that, would extend halfway too the wheel, and not allow the suspension to move without a rediculous amount of binding,
    Alma, Michigan
    12,314
    Bolting on another piece to the existing shaft is going to do three things:
    1) put the geometry of the axle way out of whack
    2) add a ton of stress to the differential
    3) allow a lot of slop or play in the axle
    The engineers at Traxxas know what they are doing... at least in this instance.
    Jun 2004
    1,894
    Those cups are really long to accommodate for the long travel in the Rustler's rear suspension, they wouldn't need to be quite that long for the MERV. I like what Traxxss did even though I don't use them.
    Bolting on another piece to the existing shaft is going to do three things.
    I'm Airmaxx23 and I support this message...
    530
    Is it the design you think is flawed or are you simply upset it's not as easy to install?
    What benefits would there be with the grub screwed on vs the TRX option? Seems the only issue pointed out is the diff need be taken apart, so what. That's not a design flaw but a lazy user overwhelmed by a 30min install, maybe a RadioShack RC is what ur after. Tongue in cheek. Look at it as an opportunity to get more familiar with your MERV and shim up the diffs
    Slovenia
    322
    Quote Originally Posted by Assassin View Post
    Yes the only issue pointed out is the diff need to be taken apart.... I just didn`t see (and still don`t, tbh.) the point...
    I`m not lazy I just hate useless work, beside that I had to take it apart due to broken bulkhead anyway.....
    And RadioShack RC is not for me, that`s for sure, I have been into models probably before you were born .....
    530
    The content of this post has been remvoed for multiple rule violatings
    Dadx2mj
    Feb 2002
    9,352
    some people feel that they are better than others, and like to talk smack when they have no idea what is happening....
    those people are good to have around for my entertainment purposes
    Sep 2012
    Greenville,SC
    85
    The dogbone style is really old tech, way before the u-joint(usually 4 points of articulation) or CV joint( 5 or more points of articulation).
    Jun 2004
    1,894
    Quote Originally Posted by RCinSC View Post
    Everyone's talking about the dog bone style end of the Traxxas CVDs that goes into the differential output.
    Sep 2012
    Greenville,SC
    85
    Exactly. It's based on old design ideas from before the 1900s, maybe even 1800s. It would be nice to have a design based on true CVs or stronger Ujoints from Traxxas. In the designs pictured here the cups ears have to be fairly long for the travel lengths. The longer cups are not efficient, cups in general aren't efficient as they can bind twice per revolution. The joint on the axle end of the Summit is pretty efficient.
    Oct 2012
    74
    With a fixed joint on both ends, how is the axle supposed to move in and out.
    Sep 2012
    Arizona
    84
    well the obvious answer to that is a slip yoke like in the stock axles but you can only make those things so small before they become fragile. could only imagine how many axles we would go through if we had smaller slip yoke on the stock axles with the motors we run sheesh o.o
    Jun 2004
    1,894
    Quote Originally Posted by SiNiST3R View Post
    Basically very similar to the stock plastic shafts just made out of steel. I used this style on my basher Slash 4x4.
    Oct 2012
    74
    I can't see the picture, just a little box with a ? In it
    Jun 2004
    1,894
    Try again...I was editing the post. It should work now.
    Sep 2012
    Greenville,SC
    85
    This is how the real trucks/cars are done. Remember when CVs first came out a lot with front wheel drive cars and the massive failures. Designs had to be improved
    so cal
    9,244
    Traxxas cvds hold up pretty good other than bending in a good crash or common wear
    Oct 2012
    74
    Looks pretty sweet' but at the same time a heck of a lot of rotating mass.
    Jun 2004
    1,894
    They added quite a bit of weight to my basher Slash 4x4 but they were probably the only thing that I didn't break.
    Oct 2012
    74
    So the Traxxas style is lower mass, less drivetrain loss, and unless you have problems breaking them, more efficient in the thend as the additional mass of those CVDs cancels out benefits from the joint on each end, unless ofcorse you constantly breaks the Traxxas CVDs making this option more desirable.
    Alma, Michigan
    12,314
    Except it isn't an option...
    As far as I know, MIP does not make a set for the 16ths.
    Jun 2004
    1,894
    They don't, I just posted the pic for visual reference.
  33. #33
    Sep 2012
    Greenville,SC
    85
    I would buy them if they did. The ends on that design are like the axle ends for the Summit.
    In the meantime, I'm going to try and develop a u joint retainer to try to keep the joints from seperating. Or maybe take the Traxxas joint, cut off the 4 pins then drill and tap,etc--but that's a lot of work. I'm sure there's other options too, such as trying to use the same type of joint in the drawing on the diff end.
  34. #34
    Sep 2012
    Arizona
    84
    I think the issue here isn't even traxxas not engineering something a certain way but more of physics at the scale the merv an other vehicles are at don't handle the power or wheels we are pushing them to handle.
  35. #35
    so cal
    9,244
    The 7151x are plenty strong. You don't hear people twisting them under power and they do a good job for how light they are.
    The cvds on my t maxx are huge!
  36. #36
    Aug 2007
    So Cal
    21,511
    A few posts have been edited in this thread. Please guys this is a Traxxas only forum so let's leave the talk about other brands out of the conversation.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
  37. #37
    Oct 2012
    9
    While were talking about cvd's, does anyone know where i can get a replacement pin from? see pic.
    I lost the pin that was under the rubber band. Surprisingly, after the bad landing the rubber band was still in place so the pin must have snapped... having shot bearings in the carriers might have played a part.... is there a rebuild kit out there? Anyone elsehave the same problem?
    Oh, also, does anyone know where i can get the grub screw pins from (2nd build)? i have searched high n low... Thanks
  38. #38
    Feb 2002
    9,352
    there is a rebuild kit available, not sure if it has those pins or not, but i think you can buy those pins in a replacement set also
  39. #39
    Oct 2012
    9
    well i think your wrong jimbo! Jokes, nice footer lol!
    I have searched for a while and cant find them.... Can anyone give me a link pls?
  40. #40
    Alma, Michigan
    12,314
