Results 1 to 12 of 12
    Bargo
    18
    Smile Traxxas LiPo 3S 11.1V 8400mAh 25C - ON 4x4 slash
    Hello,
    This is my first RC car and loving it!
    I'm just curious with these Traxxas LiPo 3S 11.1V 8400mAh 25C battery's if a stock slash 4x4 with a parallel connector could run these or do i need to upgrade anything? Im thinking maybe fans or something but i don't really know.
    I also have the IMAX b6ac charger for these batteries and i am worried that i will not charge the battery right and it will blow up on me, what is the optimal settings for charging these battery's
    Thankyou
    friendswood texas
    1,733
    Get a temp gun to monitor motor temps I try to stay under 175. You need a charger that will balance charge lipo and storage charge for when the lipo is not used.
    Bargo
    18
    Thankyou Steve,
    Yea im pretty sure that the IMAX b6ac can do that, and is that 175 Fahrenheit?
    and so i can run those batteries in parallel?
    Saint Louis, MO
    498
    You want to run 2 8400 mah 3s lipos in parallel? Why?
    With 3s your temps will be higher and with a mah that high I don't see the point of running two in parallel.
    I think you will be perfectly happy with one.
    Bargo
    18
    Just for longer run time..
    friendswood texas
    1,733
    with the mah available now you only need one battery at a time. Especially 3S
    Bargo
    18
    Okay, thankyou and another question what would you recommend for best charging, and battery life for this?
    kansas
    8,677
    other than saying Traxxas in the fourm, we can't say...
    Hit the search button & you will get several options...
    search 208B or 206B
    http://traxxas.com/forums/showthread...=1#post5098384
    Bargo
    18
    No sorry like i meant how many amps or whatever, and discharing and and that?
    81
    sorry, reviving,
    wondering what battery holder part i would need if i want to use this battery in my LCG 4x4 slash.?
    is it part #TRA7426X ?
    20,069
    That is the correct part number for a LCG Slash.
    Alt-248 on the number pad =
    RC Qualifier Panamon Creel's Avatar
    Oct 2014
    Central Mexico
    427
    Quote Originally Posted by zanderab View Post
    Hello,
    ....I also have the IMAX b6ac charger for these batteries and i am worried that i will not charge the battery right and it will blow up on me, what is the optimal settings for charging these battery's
    Thankyou
    The IMAX B6AC will work fine for your 3S 8400mAh battery, however it has 5A/50W charge limit therefore will only give you a max. charge current of about 4-4.5A depending on charge level due to the 50W limit even if you set it to 5A so charging will take some time.
