View Poll Results: how do you like my thread
Voters
30. You may not vote on this poll
  • like
    28 93.33%
  • dislike
    2 6.67%
Page 9 of 22 FirstFirst ... 789101119 ... LastLast
Results 321 to 360 of 841
Thread: Kawasaki e revo
  1. #321
    9,244
    Thanks craig. Guess you seen the sway bar will work with the rockers!
    I did it just to be on the safe side
  2. #322
    Norway
    290
    How exactly do shocks/push rods attach to those rockers? Do you use stock screws/ball links?
    Bah, those things look cool as ****, and I've already ordered a set anyway, but I can't get over how unforgiving impact physics will be to them.. :P
  3. #323
    9,244
    Yep. All stock screws and ball links
  4. #324
    9,244
    And where I need to grind
  5. #325
    9,244
    Did a little grinding . Not too hard on the bits other then the aluminum oxide bit clogging up a bit
  6. #326
    San Diego, California
    507
    Hey dave, what bits are you using for that? That looks like some serious work on a dremel! Mine is starting to show signs of going out just doing the stock plastic ones. How hot does the aluminum get when your grinding on it? any lubricant like wd-40 needed? I may do that sometime in the distant future if I kill plastic ones with ease.
  7. #327
    North Louisiana
    235
    If this proves to be good I figure I might do both the front and back on mine. I have found out my son is a hard basher on his summit. He bent 3 of his push rods and he broke off the front skid plate dont know where it whent and he busted the front bulkheads on both sides. I think he may have messed up the front differential as well. But I am still building pinewood derby cars over here.
    If its not breaken then your not racing.
  8. #328
    9,244
    I use one high speed cutter and one aluminum oxide. Tonight was just playing around with it. Was getting warm but most cuts are only fine grinding and taking my time so no lubricants yet. Looks to be easy just a few spots that need work. Seems easier to see with aluminum what needs to be done
    Take it easy davis
  9. #329
    9,244
    Quote Originally Posted by clp71220 View Post
    He sounds like my daughter!she bashes pretty hard the first time she hit the dirt she was hitting big jumps with the truck nice and level
  10. #330
    4,864
    Now what depth do you have to go on those? That's a lot of grinding my kinda work I sit for hrs doing that but dremel won't allow that gets too hot.
    DEU 8:18 ESV
  11. #331
    9,244
    Center part very little but now if the whole bulkhead bends is it really worth it
  12. #332
    3,338
    From what I recall, I think others had tried but went back to stock...I thought you may of had better luck .
    Rock n Rolla !
  13. #333
    9,244
    Spent a couple hours looking to make a good front chassis brace. No room for anything real strong
    On my merv with the aluminum bulkhead never had a problem. Don't know which way to go
  14. #334
    9,244
    I guess I will try the integy and I have an idea for the chassis brace. Now just looking at more down time!
  15. #335
    3,338
    I would give that Integy bulk a try and see how you go...maybe it will last. If all fails you could go back to the stock ones.
    Rock n Rolla !
  16. #336
    North Louisiana
    235
    That would mean!!!! " In the back ground the song "Another one bites the Dust" starts playing." And we sing" $100 bit the dust. Yeah $100 bit the dust." Corney I know. Awww man I hope this works.
  17. #337
    9,244
    I hear that! Now can't get queen out of my head! Thanks
  18. #338
    Essex, UK
    151
    The front brace I made is pretty strong, its removed any flex from the Front. Does require a little cutting of a pushrod though.
    take a look see if it gives you any idea's
    http://traxxas.com/forums/showthread...nterpretation)
  19. #339
    Norway
    290
    Does the front side need a brace at all?
  20. #340
    9,244
    I remember seeing that a while back. Good job! Thinking of doing some kind of combo using upper and lower braces. Thanks
    If I am going to use the integy with the few that have used it and bent theirs yes it needs some help up front
  21. #341
    9,244
    this is one idea for a front brace. i threaded one end and fits right under the shock mount .i will take up the extra space with washers
    still need to clearance the front a little to clear the shocks
    with this i can still put a rod along the top too
  22. #342
    4,864
    that brace looks stronger than a rod modded to fit there! looks nice on there and looks to fit nicely.
    DEU 8:18 ESV
  23. #343
    9,244
    I had used all my stainless steel and hit a few hardware stores looking for something. Want sure it would fit but should be pretty strong
  24. #344
    May 2009
    Edmonton, Alberta
    3,663
    a little off topic, but 50 how did you get those shock boots so even and smooth. Either this guy sent me the wrong length or they are made to be trimmed. I installed them on my summit and its a mess lol.
  25. #345
    9,244
    I usually trim mine. They are made to be trimmed with no fraying. Leave about 1/2" on each side
  26. #346
    May 2009
    Edmonton, Alberta
    3,663
    Are they the ones that kalisch sells on ebay?
    The kinda look like a different material now that i look at mine up close.
  27. #347
    9,244
  28. #348
    May 2009
    Edmonton, Alberta
    3,663
    ahh ok, yeah i wasn't gonna pay $40 for shipping from them... Criminal to Canada. No way was i gonna pay that.
    Im gonna try to trim mine down. They are a lycra material.
  29. #349
    9,244
    Shipping is crazy. Only ten bucks shipped. Very light what a rip
  30. #350
    May 2009
    Edmonton, Alberta
    3,663
    he claims $40 shipping minimum on any order to Canada is the only way to ship it insured and tracked. (lies) but w/e im not gonna try and argue with him. Some people are just nuts. lol
    I redid one of my summit shocks just now and yeah i can trim mine down too, cleans em up nice.
  31. #351
    37
    Had a look into those as well , the 40$ fee is a rip-off , maybe he uses ups or fedex instead of usps ..
  32. #352
    May 2009
    Edmonton, Alberta
    3,663
    Doesn't matter, at that weight, if i paid him $40 i want them at my door at 9am the next day.
    But enough of this bad horsie bashing, now back to your regularly scheduled awesome build thread.
  33. #353
    9,244
    Glad its looking better!
  34. #354
    9,244
    So with my money pit I am thinking that roll cage. No brace & plastic bulkhead just trying to get this truck tough because money will be tight for a while
  35. #355
    507
    Did you junk the aluminum bulkhead???
  36. #356
    9,244
    It was almost ready to go in but it will be too heavy as is. I did that with my t maxx big block and lots of aluminum to make it stronger and it was slower then my small block
  37. #357
    9,244
    For all of you who never had or seen merv parts check out how small the bulkhead is!
  38. #358
    3,338
    I tried the roll cage before...I didn't like it so took it off and sold it. If like me you are forever tuning your truck, changing gearing, working on shocks etc you are going to find the cage a pain in the butt....unless you have really small hands unlike me.
    RC Solutions Roll cage.
    Rock n Rolla !
  39. #359
    9,244
    I never liked roll cages but if the front bulkhead lasts longer its something to consider
  40. #360
    9,244
    I have it all together finally and took it out front. Didn't charge my batteries they are at storage charge but still ripped pretty good!
