Results 1 to 12 of 12
    Nowhere, Québec, Canada
    408
    help for tire choice
    'Sup everybody,
    I was looking for good 2.8'' tire. Type of terrain: loose dirt, hard dirt, small gravel . I've seen that many of you like trenchers, trenchers and trenchers on desperado. Are they fine for this?
    I was also looking for a ''masher'' style tire
    Which are better for what I want to do?
    Wales in the UK
    6,462
    I love my trenchers they are great for every type of surface i have tried but you could go with the mashers but you will need 2.2" rpm offset wheels. my next set will be dirt hawgs because they are lighter and smaller as well....peace
    RC Champion No One's Avatar
    May 2005
    Minnesota
    1,186
    I really like my masher 2K
    Both good tires.
    I have found the Mashers last longer
    I mounted my set on RPM Revolver Wide rims
    http://www3.towerhobbies.com/cgi-bin...&I=LXTAE8&P=ML
    Slash 4x4
    Stampede 4x4
    Stampede 2WD
    408
    Thanks guys, I found exactly what I want. this:
    2.8 Proline Trenchers on 2.8 Proline Desperados
    Or this:
    2.2 Proline Masher 2000 stretched on 2.8 Proline Desperados
    which one do you recommend me????
    Wales in the UK
    6,462
    The trenchers look more evil man...peace
    Rotterdam, Netherlands
    8,570
    The soft side wall of the Trenchers makes the car a little bit more wobbly but on the other hand it helps the Trenchers to keep the grip longer before it starts to slide. I often run with JConcepts G-Locs which make it roll less, but it also slides sooner when the surface gets more slippery.
    That same difference might be the case between the Trenchers and the stretched Mashers.
    Salisbury, NC
    633
    I run mostly on dirt (hard and soft), gravel and a little grass. The Trenchers have more grip vs. the Masher V style. My Desperado wheels are a bit too fragile for my liking though. If you jump then tend to get cracks and then get out of round. That's because the rims are too thin for hard bashing and there's no strengthening ring on the inside like there is on the outside edge. You might try to find a tougher 2.8 wheel (good luck!). I'm running on 3.2 Revolvers now. They can take the abuse.
    Wales in the UK
    6,462
    Rob my desperados are weak as well so i now powerflex to bond the hex into the wheels and my probs have gone because it makes it all solid...peace
    Davenport, Iowa Quad Cities
    2,471
    Trenchers are always a great choice for sure...
    Dec 2009
    Pa
    774
    Proline just released mashers with traxxas style beads in 2.8. they are some of the best all around tires
    Revenge 1/8 buggy
    Wales in the UK
    6,462
    Well i will be getting a set mashers as soon as they come to the UK...peace
    408
    Finally, I bought trenchers. Thank you everybody!!
