View Poll Results: how do you like my thread
Voters
11. You may not vote on this poll
  • like
    8 72.73%
  • dislike
    3 27.27%
Page 6 of 20 FirstFirst ... 4567816 ... LastLast
Results 201 to 240 of 777
Thread: new maxx
  1. #201
    9,244
    Does anyone know why e maxx forum only has 82 threads
  2. #202
    4,864
    i see hundreds
    DEU 8:18 ESV
  3. #203
    9,244
    You do? I only get 3 pages!
  4. #204
    BNE
    704
    I get hundreds too.
    Always get a 2nd Opinion!
  5. #205
    9,244
    Figured it out! At the bottom of the page is thread display options don't know how it got set like that!
  6. #206
    RC Champion SLW-SVT's Avatar
    Lake Jackson, TX
    1,638
    Quote Originally Posted by EMAXXBRUSHLESS View Post
    SLW-SVT, What weight diff fluid did you put in your castor diffs when you got them?
    50 togo, I used the 1/32" alum spacer on the ring gear side with the castor diff and flm hybrid. was just right on mine for the mesh.
    iirc i put 5k up front and 3k in the rear. or the other way around. I should log this kind of thing
    X-Maxx Max6 | EB48.3 | ET48.3 | Axial Grave Digger
  7. #207
    9,244
    Why so light on the diff oil?
  8. #208
    9,244
    Finally installed my Boca orange seal ceramics in the motor!
  9. #209
    BNE
    704
    Nice. Let me know how those bearings go. Thinking about doing something similar next time I service mine.
  10. #210
    4,864
    will check back to see how they work out on the bearings. now those are specific for motor bearings or just the size bearings that are used for the motor?
    DEU 8:18 ESV
  11. #211
    9,244
    Motor bearings
    Better then their yellow seal!
  12. #212
    4,864
    good to know thanks.
    DEU 8:18 ESV
  13. #213
    9,244
    Nice avatar Mike!
  14. #214
    4,864
    thanks i thought about changing it. I might put another up sometime when i take a better pic.
    DEU 8:18 ESV
  15. #215
    9,244
    If you have some pics to choose from and want an animated avatar like mine let me know
  16. #216
    9,244
    I now believe my project is cursed!
    I received the hyper 7 diffs today. Took one out and put it in the bulkhead its a bit wider than the losi and looks like it will work without a lot if shimming. Then grabbed the other diff and they sent the wrong one. A spiral!
  17. #217
    9,244
    But I did receive these from flm (and they didn't charge me!) Spacers and extended shafts to make up for the ring gear being pulled in from the shims
  18. #218
    9,244
    With the losi diffs it would take 1.61mm of shims
    With the ofna hyper 7 diffs only takes .40mm !
  19. #219
    4,864
    thats a somewhat improvement over the thicker shim. is it fitting better now and able to use it?
    Ill wait and see what works the best before buying anything.
    DEU 8:18 ESV
  20. #220
    9,244
    So far I really like the hyper 7 diffs and the seller just got back and is shipping out the right one so I can assemble one side now while I wait for the other
  21. #221
    4,864
    Good thing you got a good seller. Just sold all but the bodies of my pede and 4tec now. $13 from my icharger now! Lol only that I know.
    So the hyper 7's are suppose to be stronger than the losi diffs? Or just larger?
    DEU 8:18 ESV
  22. #222
    9,244
    Thicker ring gear so it uses up more space. Looks good
  23. #223
    4,864
    Ooh OK I see. Are they hard to work with? They don't happen to fit stock bulkheads? Haha dumb
    DEU 8:18 ESV
  24. #224
    9,244
    Not too bad. Hardest part is all these bolts and no instructions
  25. #225
    Middle of the Pacific Ocean
    171
    I may order a set as spares.
  26. #226
    9,244
    I was going to see if I could swap the hyper 7 ring gear on my losi cup (so I could run the Hr cup) but whole different design. O ring instead of a gasket and taller spider gears
  27. #227
    9,244
    More trouble
    Flm's stub axle is cut too
    Compared to stock
    The pin for the summit axles wont fit through
  28. #228
    9,244
    I ended up pulling the 5454 stub axles out of my stock axles and cutting the threads off them. Since I am running the hyper 7 I don't need as much shims and it works fine
    Then I forgot I used my spare pins to mount my traxxas center cvds to the cups so I had to order those
  29. #229
    BNE
    704
    I see the "bullet proof build" is progressing nicely.
  30. #230
    3,338
    Looking good mate...nothing like modding all the time .
    Rock n Rolla !
  31. #231
    9,244
    forgot to order a few small parts so little modding to make it bulletproof won't hurt a thing!
  32. #232
    9,244
    Figured might as well do this right!
    Just ordered 8 boca yellow seal ceramics for the diffs. Had a 15% off coupon that boca just sent me
    I have a full set in my merv and my erbe. Great bearings very smooth!
  33. #233
    9,244
    And now to hook it up better an Hr double update clutch. Twice as many clutch pads!
    This is the same but on my revo
  34. #234
    4,864
    So where do you get that setup at? Now when the pads wear isn't it more money for 6 pads? What benefit would you get from that CP setup? Does it mount up just like the old setup? No mods needed. Sorry about the questions 50 just want to learn new stuff so I can try these later on.
    DEU 8:18 ESV
  35. #235
    Brookline, NH
    1,229
    50 togo, I like that clutch. Somthing new I havent seen yet. part#? After all the money i have spent on my maxx trucks im not to woried about the cost of three more clutch pads. Like mike said, new stuff to try.
  36. #236
    9,244
    Bolts right up with no mods. Same width even!
    Will last twice as long at least and I figure could handle more slippage if I needed it
    Here is where I got it http://www.ebay.com/itm/150987502798...84.m1439.l2649
    I am also running hr hard anodized clutch pads. Trx15hsl. And yes those pics are from my revo parts are in the mail!
  37. #237
    Brookline, NH
    1,229
    LOL I just found it. I must have one. Theres a a lhs close with free shipping. It never ends. Thanks mate
  38. #238
    Albany, New York
    489
    That is one beefy looking clutch with twice the number of pads
  39. #239
    Albany, New York
    489
    Your thread is just wicked, defintely going to be one of the pioneer emaxx build threads. Do you have the model number and where I can find that HR clutch? Anything else needed to install it?
  40. #240
    Albany, New York
    489
    Just wondering what anybody had to think about this and if it would be a better step to take for all of us versus the castlefan?
    http://www.ebay.com/itm/120845422648...84.m1497.l2649
