Thread: Can U?????
    697
    Can U?????
    Can you put an E-maxx 32p pinion and spur geaR on a slash 2wd???
    thanks
    SLASHING UP WITH MY PEDE
    Feb 2007
    NYC
    756
    yes direct bolt on you don't need anything else. Jato spurs might be better.
    Knoxville, TN
    592
    No the emaxx has a larger clutch it looks exactly the same but it is bigger. You can use one off a jato or slash 4x4
    Feb 2007
    NYC
    756
    jato spur + emaxx pinion is a good cheap upgrade. Will not require the gear cover either.
    14,885
    The emaxx spurs are physically way too big, but the jato 56 and 54 spurs are a perfect fit to go along with the 3.17mm emaxx pinions. The brushless emaxx 5mm pinions will need a motor with a 5mm shaft, or a bore reducer to fit motors with the 3mm shafts...
    Ya can't polish fertilizer...
    Knoxville, TN
    592
    Slash 4x4 parts !!!!!
