Results 1 to 12 of 12
    Australia
    419
    Driveshaft question
    Hi, guys, I'm back after a long camping trip. I've just got a little question, I understand that everyone says "if your goings to that motor you'll need steel driveshafts!" (I'm getting the got2gorc drop in). What exactly would happen if I used the stock driveshafts with a more powerful motor such as the one suggested?
    Slash 4x4 VXL
    Slash 2WD
    Slash 1/16 VXL
    Rotterdam, Netherlands
    8,559
    Quote Originally Posted by hammertron2000 View Post
    You could just break them. I don't know if the got2gorc combo will deliver that much power that it will ruin your drive shafts right away.
    Drive shafts suffer more from a motor that has much torque. Once the car is running, the chance of breaking is not that huge. It's the accelerating and braking (or full throttle or full brake landings) that give the most stress.
    Australia
    419
    Ok, I was just a bit cautious because I'm pretty much broke and I could barely afford the motor and esc by themselves, and I'm pretty easy on the throttle anyways.
    Slash 4x4 VXL
    Slash 2WD
    Slash 1/16 VXL
    Alma, Michigan
    12,314
    I am running stock shafts with more power without any issues.
    Slipper settings and throttle control are key.
    so cal
    9,244
    That motor is plenty powerful!
    Jun 2004
    1,894
    This X10, having your slipper adjusted properly will allow you to use the stock drive shafts without and issues
    ***You Build It ...I'll Jump It!!!*** OS .18 TZ; Trinity Pipe; HCR Titanium Skid Plates & Bumpers; Futaba S9450 Throttle Servo; Airtronics 94358Z Steering Servo; RPM A-arms & Knuckles; FOC; Lunsford Titanium Hinge Pins,Turnbuckles, Push Rods & Rocker Posts; New Era Roll Bar & Engine Mount; Proline Mashers on Velocity Rims.
    Australia
    419
    Without trying to sound like a newb, (I'm still learning about the construction of the merv) how do adjust the slipper clutch?
    Slash 4x4 VXL
    Slash 2WD
    Slash 1/16 VXL
    Alma, Michigan
    12,314
    With a really big hammer.
    Just kidding!
    Page 23 of the manual:
    http://traxxas.com/sites/default/fil...l_100205_0.pdf
    Australia
    419
    Don't worry, just figured out how to, but which how much should I turn and which way?
    Slash 4x4 VXL
    Slash 2WD
    Slash 1/16 VXL
    Alma, Michigan
    12,314
    DIRECTLY from the manual:
    Turn the adjustment nut clockwise to
    tighten (less slippage) and counter-clockwise to loosen (more
    slippage)
    Australia
    419
    Do I want more or less...?
    Slash 4x4 VXL
    Slash 2WD
    Slash 1/16 VXL
    so cal
    9,244
    Snug the nut and back off about 1/2 to 3/4 turn
