I notice you say you planned on 6s but you charge a 2s. So did you charge 3 of them or only one?? LOL......OR.....did you leave all the packs back at the house on the charger?? Trick question??
Weak Revenge
Strong Forgive
Intelligent Ignore
no, i meant to say, after i charge my 2s, i strap it on top of 4s and hit the street for a test run and did'nt turn out well. i got a good distance and turn around, i take it easy on the throttle until the speed picked up and floor it and just right after it passed me, it literally flew up in the air about 4 feet and skid about 20 feet, good thing it skid straight in the middle of the street upside down lol. from a distance, i turn left to right with the steering control and i got no respond...and bad thoughts quickly running thru my head but, when i got there to pick it up its just one of the batt got unplug. everything else looks good except for the body and wheels all scratched. from now on i'll keep it on 4s lol.
Awesome build mate...I want to join the gang too!!
I've got a list of questions I want to ask you about your build, thinking of doing something very similar maybe late this year. It will be difficult trying to justify another truck to my wife.
Rock n Rolla !
lol, anything i can do for a friend. you can always take her for a nice vacation like the last time![]()
update:
i made a front under tray defuser, i hope this will help flow the trap air around that area lol.
its made of plastic cutting board.
Ok just received all the parts to do my axles like yours... Hoping to have it done this weekend.![]()
On road with a pf8 body and tenshock 5200kv so I can keep using 2 cell. My 4 cell are all for my planes and helis. Not hard cases.
Oh, and I'm using a strc lcg chassis instead of the rally chassis.
Well, here's what's sitting on my work bench... There's enough parts left over for a full on rally (need chassis, body, tires and electronics)
I am using T-RCE shock towers on this to try them out. The diffs are FLM aluminum cases too. This will be fun I think.![]()
That's a good question... I may have to look into that. I'd like to have something that could kind of "seal" the underneath of the car.
i know 1 guy did a XO-1.......shortened the wheelbase to fit a PF-8 body. i'm thinking of doing the same but, i dont know yet.
so far i did the front defuzer i posted above. working on the side and rear lol.
How do you feel about the handling after the mods you have completed so far? Is it a major improvement over stock? For the cost of all the parts I am starting to think i might just buy an xo-1.
Hey mate...what are the dims of the suprasale slicks you have? I am looking for the height and width please.
Rock n Rolla !
stock is for offroading and can easily be tuned to handle real good by slapping a set of Rally GTR shocks. i have watch a youtube video with a rally WP SC8/4000kv 3s vs XO-1 6s. rally looks like its not set-up for onroad.
http://www.youtube.com/watch?v=T5z8IuqiIw0
i video another short run at a dusty parking lot
http://www.youtube.com/watch?v=HNNFX...ature=youtu.be
Yours seems to handle great, looks like it would give the xo-1 a run for its money. Durability seems to be another plus, if I do the rally. Still have another day to debate....
Are you running your Mamba Monster in there mate?
I think I am going to build myself a rally. I have a Tekin RX8 2000kv combo, not sure what to do with it...it might be a bit overkill for this rig...I just shredded all 4 of my 1/8 buggy road tyres on my eSlayer today...and they were taped.
Rock n Rolla !
its a whole lot easy to run than to compare with my smaller 1/10 TC3, i can tell you that. being its wider than XO-1 my stability is amazing and can easily make a sharp turn. as for durability...get the chassis brace (axxis) unless you go with STRC LCG aluminum chassis only prob that i see with the aluminum chassis is that its limited to 2s/3s batt unless you trim the upper brace then you have room to fit a 4s.
yes mate, that my MMM/2200 in there lol. now that all my drivetrain are very solid, i decided to put them for a test run and i think its staying in there lol. are your onroad tires soft compond? the one i'm running are hard compond but not belted and i get plenty good run. my next purchase will be the XO-1 wheels/tires.
Yeah mate...pulled the trigger and bought a roller today with a few odds and ends. I liked your build so much I wanted to do something similar to you...I bought XO 1 wheels today, that's why I was asking you the Q's. I ended up buying 2 sets of fronts as I think the rear come with an offset and are 10mm wider.
Still undecided for motor and esc...
I should have everything in a few weeks...not sure how I am going to explain this one...savings depleted once again. All for the hobby mate...I have shelved my SlayVo GT build, your rally build looks way more fun.
As always...another great build mate.
Rock n Rolla !
its been a while since i visited the traxxas site...the moderators here really didn't like me...so i've been staying away...but aside from that...i just wanted to congratulate u on a fine build Humay....u are truly an inspiring individual...keep up the good work...u have a loyal follower in me...and i have always looked to ur builds for inspiration...thanks!!!!
i did some few adjustment on my front diffuser, due to the kick up the diffuser also pointing up, so i tuck in a foam enough to get it straight with the bottom chassis. i dont not have any movement of the body whatsoever now that i got it all secured, i can push down the hood part and i can actually see the suspension goes down and not the body flex down lol.
also move my antenna tube next to the reciever box.
Maybe I am seeing things but does that battery hold down fit the emaxx? Looks like the same holders to lock it into. This one is 29mm just a little bigger than 28mm that I have. Wonder as if I get a battery that is larger than I have.
Living life.
I see you are running the 1/8 slicks from suprasales. How have they held up for you and what do you think about them. I purchased the same set and also a set of on roads from them.
Weak Revenge
Strong Forgive
Intelligent Ignore
so far its serving me well that i bought another 2 set from him. this black one is my first purchase from him and i'm still running them now lol. i get lots of run with them and i dont just take it easy too, i do drifting and burn out and still intact. i do wanna try the XO-1 front wheel/tires though just to see the differences.
Living life.
that would be awesome running it on 5s and with that high mah your run time will be much longer too.
i have 4000's right now and get like 30-40mins running 4s thats near full throttle runs and fast take off's plus braking though i have brakes set at 25%. 6500 will give me maybe what 45-60mins maybe. 5s will be ran flat mostly maybe dirt but no pot holes or off road too much
ooh yeah esc cant handle 5s darn forgot about thatooh well 4s will be good enough till i get another esc perhaps
Living life.
