Page 10 of 34 FirstFirst ... 8910111220 ... LastLast
Results 361 to 400 of 1334
  1. #361
    7,264
    this is before I have the XO-1 17mm adapter, what I have on here is my REVO 17mm as you can see the wheels a bit flush in, I wanted it a bit more out.
    with XO-1 17mm adapter
  2. #362
    7,264
    didn't like how the body move around like it need support so, I put a side body post.
    also a bumper foam to support under heady pressure of high speed pass
    then, I thought the foam bumper is not supporting the body too well...added the XO-1 bumper just need some trimming to fit then added a diffuser underneath.
  3. #363
    7,264
    keep it like that for awhile, at the same time building an XO-1 and from there I keep thinking of how to put XO-1 diffuser on my Rally GT8 then, I come up with this,
  4. #364
    7,176
    Dude that is totally awesome build bro!! Let me know when you want to pass it along. LOL
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 4
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
  5. #365
    7,264
    Quote Originally Posted by DiggerPede View Post
    at one point I had it at MP to fund other build but no interest so, I decided to keep it, by means keeping it for good
  6. #366
    Jul 2012
    Yakima, Washington
    1,440
    That looks totally wicked. Nice job
  7. #367
    7,176
    You catch the bumper support in the window just right, looks like a dashboard.
    That sucker is meaner looking than an XO, BTW.
    How fast you got 'er up to?
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
  8. #368
    7,264
    I didn't even think about that
    thanks, i'm very happy with how it turns out.
    I never really clocked it though so, I don't know how fast it is
  9. #369
    Canton Georgia
    2,149
    How is the lateral grip?
    Slash 4x4 LCG+(rolling)HCG, Slash 2wd(raptor)
  10. #370
    Jul 2013
    Saskatoon, SK. Canada
    2,187
    Okay, Nice looking last build, but I'm really confused regarding the Protrac arms and my Traxxas 6851/2R drive shafts... Can I still use them together with the extended track width?
    Protrack states:
    "**While the stock axles will work with the ProTrac™ Suspension Kit, some customers may want a heavy duty CVD option for their truck (for Racing or Extreme Bashing purposes). The following MIP option has been confirmed to work with the kit:
    MIP #11104 X-Duty CVD Kit (2 Required for Front and Rear)
    MIP #10133 X-Duty Front Axle (2 Required for Front Left and Front Right)
    Additional note: If you already own X-Duty CVDs for the Slash®/Stampede® 4x4, you can use MIP #11105 Male bones to convert your drives to the new length. Axles can then be skipped in this case."
    Seems the formula is there...?
  11. #371
    7,264
    Quote Originally Posted by ViperZ View Post
    Protrack states:
    the stock axles they're mentioning are the plastic ones. The splined CVD's from traxxas, your telescopic splined has very little amount of contact, that is why I didn't use my XO-1 driveshafts and went with tekno hybrid instead.
  12. #372
    Jul 2013
    2,187
    Okay, thanks.. I'll see how it all settle in, but maybe a set of MIP's like Pro-Line indicates may be in order...
  13. #373
    7,264
    with the new keyed stub axle from MIP I think its a better choice than the previous hex pin type, knowing that its a 5mm stub axles cant really withstand the hard bashing/jumping and tend to break at the weak point by the hex pin.
  14. #374
    Jul 2013
    2,187
    Yeah, I'm thinking a 5mm spindle with no hole is stronger than a 6mm with a hole... I broke another one
  15. #375
    7,264
    I switch back to PF8 body with my 5 spoke wheels.
  16. #376
    7,264
    I might get a different body, well see, I have my eye on this one for quite sometimes now.
  17. #377
    Jul 2013
    2,187
    Look nice with the Inferno wheels
  18. #378
    Jul 2013
    2,187
    Hey Humay, does running the XO-1 Shock towers allow you to run the short X)-1 GTR shocks as well? I like that idea as you can use stiffer springs
  19. #379
    7,264
    Hey Humay, does running the XO-1 Shock towers allow you to run the short X0-1 GTR shocks as well? I like that idea as you can use stiffer springs
    yes you can, I even put spacer inside the shock shaft to make it even shorter and the rear I left it alone.
  20. #380
    Riverton Utah
    5,613
    How have I missed this thread for so long? Either way, nice build!
    Is owning 27 RC's too many? No way!
  21. #381
    7,264
    thanks Wolfslash16, and me I remind you, your getting close to getting your avatar, what is it gonna be? hmmmm....
  22. #382
    Jul 2013
    2,187
    Okay, so why the standard rear shock assembly? I was thinking I would like to stiffen the whole Rally assembly by using the stiffer red GTR springs, but I need the shorter GTR shocks for that. And the shock towers it would seem..
  23. #383
    7,264
    no, I have XO-1 F/R shock towers but, the rear GTR shocks I left it alone as it is, since its manageable by switching around on how you position the mounting hole and still get the right ride height.
  24. #384
    Jul 2013
    2,187
    Okay cool, I may get the Shock towers than and a set of Short GTR shocks... Are the X0-1/Jato/Revo..etc GTR shocks the same size front and back?
  25. #385
    7,264
    i believe so, except jato shocks are plastic.
  26. #386
    Jul 2013
    2,187
    Right, thanks!
  27. #387
    7,264
    digging thru my RC box and came across to my old (I believe its an OFNA PIRATE MT) sway bar.
  28. #388
    Australia
    3,338
    Still going strong, nice!
    Are you aware of any arms in aluminium that are the same length as the pro-trac...I keep breaking them on my slash so I want to replace them but keep the extra width?
    Cheers,
    Craig.
    Rock n Rolla !
  29. #389
    7,264
    Quote Originally Posted by MITCH316 View Post
    Cheers,
    Craig.
    I believe the TeamRCE magnesium arm do make it on stock and pro trac form mentioned by thedreadedend on post #263 only thing that I didn't buy it, is cause of the price but you paid what you get for the quality.
  30. #390
    7,264
    how to put XO-1 diffuser on my Rally GT8 then, I come up with this. Continued.....
    rear splitter
    cut an opening for the arm to clear.
    trim this part
    shortened this
    this is only a piece of thin cutting board that I cut to shape only to fill in the gap
    the screws are not screwed into the chassis, its only there to keep the plastic together.
    front end part
    stock bumper support cut like so
    trim this part of the arm from binding to the front splitter
    drill hole in the middle (front splitter)
    continue next post
  31. #391
    7,264
    trim this part to clear the arms
    this are the screws I use to hold the front splitter
  32. #392
    Jul 2013
    2,187
    That is so cool how you grafted on the OX-1's under tray. You had that one shortened XO-1, which made me think of getting a TRCE chassis for the Rally and grafting on the XO-1 under tray
  33. #393
    7,264
    received my Castle Motor fan today and drill some holes at both side for air to pass thru. also took the receiver out of the receiver box cause the fan plug hit the chassis brace no matter if I plug it at channel 3 or 5. I'm not really going to run this anywhere near wet surface so, this will be fine
  34. #394
    Jul 2013
    2,187
    They have been times I've contemplated getting rid of the Rx box as well... Before I move mine I was thinking about it pretty hard
  35. #395
    7,264
    I was actually trying to mount my receiver box just like yours last night and I even make a ESC mount plate to move the ESC a little bit toward the motor so that the receiver box will fit next to it but, it got complicated lol. I cant turn my ESC the other way around like yours either cause the motor wires are not long enough, oh well..i'm fine with how it turns out anyway
    got to run it today at a fresh pave parking lot..... very smooth.
  36. #396
    Jul 2013
    2,187
    Right, I was noticing your shorten wires
    Nice! I need to find some fresh open new pavement too!
  37. #397
    7,264
    only thing about the TRCE chassis is the shape of it, it doesn't seem to contour the XO-1 under tray but, all in all.... its workable. my shortened XO-1 is like the TRCE but without the aluminum bulkheads
  38. #398
    Jul 2013
    2,187
    Okay, good note to take, should I go that route at all
  39. #399
    7,264
    its your choice to go that route, I know a guy from other forum and he has the TRCE. at first it was a full race slash 4x4 at the same time a basher with not a single problem at all then, he turns it into a GT8 like ours, that's when he stripped a spur gear which he find it very odd cause he bash it hard when it was a slash in the woods and being the spur/pinion expose not one single time "he said" anything got jam to cause the spur to strip, now that its a GT8 a small rock jam, that's all it takes.
    when I have my GT8 XO-1, I saw a white stuff on my spur, i'm thinking like....what is this powder thing but, with the gear being Mod1 I guess it just crushed it lol.
  40. #400
    Jul 2013
    2,187
    Yeah everyone is telling me the Mod 1 can run open. On Road I can see, off road, there are so many variables. I still think stuff will get caught. Then they say steel gears all around. I think then a person is breaking something more expensive than plastic gears..., like motor shafts...?
    Ah well it's academic anyways as The TRCE are not in stock, so I may never get one. Just dreaming out loud
