Page 2 of 34 FirstFirst 123412 ... LastLast
Results 41 to 80 of 1334
  1. #41
    Sep 2010
    the giant boot. Anybody?
    2,726
    Did you measure to see if they fit? I just grabbed my set of xo-1 shaft's and checked to see the length they will telescope to. I'm not sure there will be sufficient spline grabbing to be happy with running the extended arm's. Just a thought.
  2. #42
    Port Alice, BC, Canada
    1,450
    your welcome mate.
    thinking of buying the extended a-arms from rc solutions to make up the width of my car body, did'nt like the look of the tires being tucked in. i'ver seen some of the extended 17mm hexes but i dont know if i want that.
    I ordered up a set of 6mm offset 17mm adapters. Ill let you know how they work out. Nice build so far man, things a beast
    R4lly GT8 | Backsl4sh | Sl4sh MT | Sl4sh | P4de
  3. #43
    7,264
    the extended a-arms gives you 1.1/8" overall width. My GT body have 12.5" width and the rally have 11" so that put me just about right where i want it to be. if the XO-1 shaft to short then i'll find some some other way.
    http://www.ebay.com/itm/Traxxas-Slas...item35c29efbff
  4. #44
    7,264
    i ordered the MMP/2400kv off ebay for $189 but, then i look around and found this. so i cancelled the first order and got this instead.
    the price was a steal, i cant pass it.
  5. #45
    7,176
    Its a 2800kv motor right?
    Sent from my Samsung Galaxy S III ~ using Xparent Green Tapatalk 2
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
  6. #46
    Sep 2010
    2,726
    A 2800kv is in the range to be a perfect motor for the Rally/Slash 4x4. I would like ot find this motor and pair ir with the MM or MMP. Let us know how it is and.
  7. #47
    7,264
    yes its a 2800kv. i figure, a 2800kv on an onroad rally GT set-up should'nt be a problem. i'll let you guys know how this one performs.
  8. #48
    7,176
    Dude that is a near perfect motor for the Rally!! How many MM is the can? Same as the 1500 series Castles right?
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
  9. #49
    Jun 2010
    Springfield, Ma.
    3,377
    Digger, same as our 1415 motors, CC 2400. And super cheap with the upgrade 5mm. I would be willing to bet the 5mm shaft is made of a different material than our green castle motors... the rep from castle said that its an expensive metal that continuously drives the price up. Maybe that's what sets these rebranded motors apart in price.
  10. #50
    7,176
    Quote Originally Posted by thedreadedend View Post
    Yeah that's what I've heard about the rebranded vs of Castle products. I've been running the mess out of the HPI 4000kv Vektors and i'm also using the waterproof vs of the Sidewinder ( HPI Vapor Pro ). They've been pretty good so far, maybe not the exact same. LOL
    If I remember correctly (duh if my memory was intact today ) Oaks did use the rotor shaft from the 2400 and installed it into the 2800kv Losi can. Ding dong no body is home.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
  11. #51
    7,264
    i recieved my rc-solutions extended arms today and heres what it looks like installed.
    lenght comparison
    i thought i got all four of them but turns out i only got two, looks like i have to order two more hahahhaa
  12. #52
    7,264
    looks like i found a cvd's that might work for my extended arms. i already have a 5mm drive cup and also order the xo-1 stub axles, xo-1 F/R knuckles
    lenght of dogbone eye to eye 3.75"
  13. #53
    Sep 2012
    120
    Do the rc solutions arms give the proper offset? I was considering building a GT rally and I wasn't sure if it would be better to use those arms or the pro trac arms with the PF8-GT.
  14. #54
    7,264
    so far its just about right. i'll post more pictures when everything are here and installed.^^^
  15. #55
    Canton Georgia
    2,149
    Looks really good!!!
    Slash 4x4 LCG+(rolling)HCG, Slash 2wd(raptor)
  16. #56
    Jun 2010
    Springfield, Ma.
    3,377
    I was just checking out my set up for long arms.... 3.25" on a standard Tekno connected to xo1 gives me these longer arms
    Yours are gonna be " longer than my mod ..... I think you went to far. But from what I can figure, either my shafts set up (can't even be used on a standard slash because the jam the diff at half way compressed shock) or Tekno axles, and your shafts may just cut it. Here's my mod with the arm level, steering turned full for max amount out of the cup
    There its jamming the diff.... if yours is to long, this may be the way to go.
  17. #57
    7,264
    how long is your arm? mine is 4 1/2" end to end.
  18. #58
    Jun 2010
    Springfield, Ma.
    3,377
    This fits a " extended arm with room to go onProtrac spec TRCE arms. I get the extra length in the xo1 axle . Here you can see how much more it sticks out.
    Don't forget, the xo1 axles will stick you with 17mm only but the new trx axles from the cvd's will get it back to 12mm and should be as long but not sure. After all is considered... either Tekno for protrac bones and new sl4sh axles give you almost " extra or the bones you have and tekno axles and hubs for an additional ". Either one lets you go with 12mm and 17mm.
  19. #59
    7,264
    i have here is an 88mm bone and it almost pop out of the cup
  20. #60
    Jun 2010
    Springfield, Ma.
    3,377
    That converts to 3.46 inches. Tekno is 3.2 and the Tekno for protrac are 4mm longer, so about 3.40 or so ....just under 3.5. Will that set you have drop into the xo1 axle? It'll give you another .
  21. #61
    7,264
    mailman drop off some packages today, i recieved my ESC/Motor and the other 2 pair of RC Solutions extended arms.
    extended arms all around and motor/esc installed
    body on
    mocked up wheels on
    thats my revo 17mm hexes but behind that are the 14mm hexes so, that put me just about right.
  22. #62
    7,264
    i made some esc plate/tray
    i did a cut-out for the wire to run underneath the plate.
  23. #63
    7,264
    i just won a bid of XO-1 driveshafts (4) for $60. not bad for never been used driveshafts
  24. #64
    7,264
    OK, i got everything wired up and for the first time plugging in the battery.......heard the usual start up rhyme tone,...then red light flashes, so ok i know i need to bind them. now its working like it should but, i notice that the yellow light keeps on fast blink,..... is that normal with MMP ESC? My MMM does'nt flashes like this.
    oo and are all castle ESC manual programing all the same? 1 thru 9
  25. #65
    34
    body
    Can you post a link to that body? I went to protoform site but I didn't see it
  26. #66
    May 2009
    Edmonton, Alberta
    3,663
  27. #67
    Australia
    3,338
    Looking good mate .
    Rock n Rolla !
  28. #68
    7,264
    thanks craig,
    recieved my 6mm stub axles today and now just waiting for the xo-1 f/r knuckles and xo-1 driveshafts.
  29. #69
    7,264
    i got my xo-1 driveshaft in the mail today and it seems like i only have a hair left with the telescopic, time for plan B.
  30. #70
    Australia
    3,338
    Whats Plan B mate??
    Rock n Rolla !
  31. #71
    Sep 2008
    NYC
    1,052
    Will the X01 shafts fit a stock Rally? What are the benefits to using them?
  32. #72
    7,264
    Quote Originally Posted by RobF353 View Post
    they make one for rally/slash 4x4 cvd just like the xo-1. the only difference betwen the two are the stub axle sizes (XO-1 6mm, rally/slash 5mm)
  33. #73
    7,264
    finding the right lenght cvd are very frustrating, i order one that i'm hoping it will be the right lenght. for the maintime i really want this to run, so i bought some Jato wheels/tires from LHS. My boy that work there he hook me up with a employee discount and he toss me a aluminum bearing adapter #6893X all for $50. what sucks about the wheels/tires is that its few mm wider that its rubbing the body wheelwell and the diameter of the tires are bigger than my onroad buggy tires.
  34. #74
    SLC, Utah
    3,432
    That is sick man... Love that body..
    Build, Bash, Clean, Repair, Repeat..
  35. #75
    7,264
    thanks ^^^^
    this thing is a rocket on 4s and eventhough i run it without the body on its still very stable, too bad i did'nt get to tape the other 2 tires as i bought it preglued but the other two i have taped it. looks like i'm gonna have to do the boiling procedure to take the tires off lol.
  36. #76
    Jul 2011
    8
    Love the PF8-GT body on the Rally, and glad to see someone else using the All-Star wheels with the Anacondas. I'm running these wheels as well (with the stock A-arms) but they are the TRA5576R (a bit more offset), which means an overall width of approximately 12.3125" or 320mm. Can you tell me if the GT body will be wide enough for this combo, or do I need to use the TRA3773A wheel/tire combo that you are using to get the tires to fit inside the body?
  37. #77
    7,264
    Quote Originally Posted by Mugsy1 View Post
    i dont know about the TRA5575R much i just went and grab some from my LHS and they are the TRA3773A preglued and i bought another pair that are not glued so that i can tape them. i ended bioling the preglued one so that i can tape it too, it was ballooning real bad. now that i got them all taped i did a few speed passes and here it is on 4s.
    http://www.youtube.com/watch?v=adbAr...ature=youtu.be
  38. #78
    1,450
    Nice, looks like it's moving along pretty good. No GPS or Radar gun? How are you geared?
  39. #79
    7,264
    Quote Originally Posted by Stephan81 View Post
    no GPS or radar gun here lol, i wish i have one though so that i know how fast it really is. i'm gearing mod1 38t/15t.
  40. #80
    7,264
    check out what i just bought off ebay......do i see 2nd build? we'll see....
    http://www.ebay.com/itm/Traxxas-Rall...item51a68e8f2b
