Results 1 to 4 of 4
    RC Racer SlashServices's Avatar
    Apr 2016
    168
    MMP 3800kv Slash stuttering under full throttle
    Sorry to jump in the list here but I have a problem with my MMP 3800kv combo slash. When I apply full throttle, the motor starts studdering but still goes. This also happens under hard acceleration. I put the VXL system in my slash and it did fine so it's not a tranny case problem and I also got a RPM hybrid gearbox and greased my gears so everything is nice and ffresh in there. Is this a motor problem or a tuning setting I need to change? Thanks.
    May 2016
    495
    Is the motor sensored or sensorless?
    If its sensored it might be the sensor cable.
    Sent from my SM-N910G using Tapatalk
    RC Champion MikeMcE's Avatar
    Feb 2016
    Deep in the Everglades
    1,291
    Castles sensored motor won't be out until mid November..... the MMP might not be set correctly.the MMP can be sensored or not . You need a castlelink for complete adjustment and or firmware updates of the MMP
    I suspect dirty or bad bearings in that motor, pull the end bell for a quick look see
    Hang up and Drive
    HANG UP AND DRIVE!
    Slash 2wd 4x4
    PRO MT Yeti 4x4
    Apr 2016
    168
    Aright thanks-and no it is not sensorer just the typical 3800kv castle motor. I will pull it apart and check the bearings although I've only had it for about a year. Is this a common problem?
