Results 1 to 7 of 7
    Aztec, NM
    56
    slayer wont start please help!!!!
    I am brand new to nitro rc. I bought a used slayer off ebay. Got it in, bought 20% nitro fuel, got excited, try to start it and it wont start. Has ez start system. Glow plug light lights up as does engine light. Cranks over but wont start. Though i flooded it so i followed procedure to un flood it. Removed glow plug, cranked it over and spit out excess nitro, installed plug disconnected ez start wire and pressed button to heat glow plug to burn of excess. Hooked up wire and still wont start. So i put carb back to factory settings and still no luck. Please please help
    2,215
    Try replacing the glow plug. Usually thats the first thing you should do with a used engine.
    Aztec, NM
    56
    Yep that solved it. Had to drive an hour to nearest HS but got er done. But now i encounter a different problem. It seems like it doesnt wanna run at WOT. And if im just cruising along and punch it it dies but i can kind of ease into it and it revs up but once I hit WOT it cuts out. Any ideas?
    5,613
    That sounds like your hsn is too lean, causing your engine to 'cut out' or "shudder" at speed. Try riching the hsn a little. Hope this helps!
    Planet Vegeta
    651
    just like he said, your engine isnt getting enough fuel in the fuel/air mix
    Aztec, NM
    56
    Thanks for your help. Still havent got it figured out but im tryin. Now if i put revo tires on the slayer without changing gearing could that be causing problems as well?
    Colorado
    98
    yes, you could have over heating issues
    I'm crazy, no really I am.
