i want a bigger fuel tank but i noticed with the tekno kit you have to remove the second serrring servo i wanna use a tank bigger than 200cc is there a way to do that with out removing the servo
drive it like you stole it
The best way is to remove the servo and use that kit. One stock servo will work fine, and when it dies you've got a spare or you can get a good one.
You could try adding a small header tank, there is a thread here somewhere showing some pics with one made to fit.
Yep two tanks!!! Lol
Dual steering servos are usually more trouble than they are worth. That tekno kit with an Ofna Hyper 7 tank is a great way to go.
Drop a quality servo in place of the 2 2075's and you are good to go![]()
So if I do that what do it have to do just pull the linkage off the right side and servo and then done
yeah realistically you don't even need to swap out the arm. You can get a better servo arm made for single servo use, but you can totally just unhook the right hand side servo and take it out.
Tekno kit installs in like 10-15 minutes, no real hassles at all.
Ok cool will have to get it cause with this 523 I'm only getting 8 mins per tank how big is the hyper 7 tank
250cc if you get the right one. Part # eludes me but it is in the instructions for the Tekno kit.
Ofna Hyper One Seven 1/7 (250cc, alternate config)
quick google shows part # 19504 for the big tank.
