Results 1 to 19 of 19
    Oct 2012
    42
    What is a good, easily to find dry lube?
    As the title says, needed for bearings and such after washing off. By easy to find, I mean like wally world or an autoparts store.
    Thanks,
    Craig
    so cal
    9,244
    For bearings you don't want dry lube but a light oil like 3in one oil will work and for a dry lube. Which isn't dry but dries with Teflon protection order a bottle of Sullivan's dry ice
    Alma, Michigan
    12,314
    Saskatoon Saskatchewan Canada
    365
    I would use a light coat of Hydraulic oil applied with a cloth; I also like LPS brand TKX spray lubricant.
    Oct 2012
    42
    Thanks everyone! I have used PB Blaster with good results before for different things, didn't even know they made a dry lube!
    Nov 2011
    Planet Vegeta
    651
    use wd-40 and it will prevent corosion
    All I need now is to set a new lap record.
    RC Qualifier MooseSlash's Avatar
    Dallas, TX
    825
    I use the Finish Line waterproof lubricant for bike chains, a bit hard to find though. ^ WD-40 is
    NOT a lubricant, it is a rust displacer or a de-seizer.
    Nov 2011
    Planet Vegeta
    651
    the old kind, mines lubricates very well, and my bearings are still strong
    Oct 2012
    Salta, Argentina
    110
    +1 to wd-40
    Alma, Michigan
    12,314
    It does not matter how old or new the WD40 is... it is more of a solvent than a lubricant.
    Sep 2012
    74
    I use silicone spray. I wipe my skid plates with it using a rag and wipe pretty much every thing I can get to (a little bit goes a long ways) I spray my ball ends, drive shafts where they connect to each other and to the joints that connect to the wheels and differentials. Keeps every thing lubed and clean.(same thing, a little bit goes a long ways)
    Sep 2011
    Iowa City, Iowa, USA
    4,346
    im giving cerflon a shot. it is a teflon and ceramic compound made by liquid plumber. first time using it but it seems to be working. it isvery watery so you have to put it on a little at a time and put on multiple coats. if you are supposed to be able to clearly see the lubricant after it dries then i didn't put enough on.
    Oregon
    119
    corrosion x
    Pittsburgh
    808
    Wd-40 works great and 3 in 1 works great. Both available everywhere.
    0111001101101001011001110000110100001010
    Nov 2011
    Planet Vegeta
    651
    Quote Originally Posted by Cipher_Jones View Post
    agreed by +1230
    so cal
    9,244
    on my other than ceramic bearings i use acer sin oil! good stuff
    RC Champion trax de max's Avatar
    1,945
    Quote Originally Posted by rcbasher View Post
    +1 I use silicone spray with PTFE, more kind to plastics and rubber than wd40.
    What i use. click
    Google search trumps Wiki. Refer to user guide.
    so cal
    9,244
    Wd40 doesn't even hurt paint it wont hurt rubber or plastic
    Nov 2011
    Planet Vegeta
    651
    isn't rp7 the same thing as wd-40?
