Results 1 to 31 of 31
    207
    How to change out the 2065 transmission servo..
    Can anyone help with this? I have unscrewed both set screws, and I see the wires going underneath the motor/transmission. Not sure I just want to start taking everything off if I dont have to lololol.
    Any help would be much appreciated.
    89
    when i did mine, i took out the motor to give me some room to get the plug out of the reviever box area, then just pulled the wire through the servo mount and out. some small needle nose help too.
    207
    Quote Originally Posted by cris View Post
    Ok thanks!! Is there a better servo i can upgrade to that has a metal gear instead of plastic?
    Sep 2009
    Victoria B.C Canada
    5,470
    Flip over truck
    two screws removes the bracket.
    The rear diff loc linkage is a ball and socket can be gently poped off
    Whole bracket off much simpler
    Sent using lipo power
    Mountains cant stop me
    they have tried
    207
    Flip over truck
    Are u talking about the tranny servo? I took two screw of the top and the servo come off. I was just wondering about the harness into the esc
    207
    Aug 2012
    Toronto
    414
    I was tinkering with mine the other week and I believe it's channel 3 on the reciever.
    Sep 2009
    Victoria B.C Canada
    5,470
    Sorry yes channel three for hi/low
    Ch 1 to turn
    Ch 2 to burn(esc)
    Ch 3 to shift
    Ch 4 front
    Ch 5 rear
    they have tried
    207
    Ch 1 to turn
    Ch 2 to burn(esc)
    Ch 3 to shift
    Ch 4 front
    Ch 5 rear
    Ok so those channels are in the esc? Sorry for being so ignorant
    Alma, Michigan
    12,314
    Those channels are describing the receiver... in the receiver box alongside of the motor. Just follow the wire...
    207
    Oh okay gotcha. The cheapest stock servos i can find are around 30 bucks. I wish i could find a servo with a metal gear to upgrade to.
    Sep 2009
    Victoria B.C Canada
    5,470
    When installed and setup right they usually don't cause much grief. Just be careful when tightening or loosening the horn.little tiny plastic teeth are very sensitive...lol hold it in place when tightening.They don't have to work very hard in theory.Sometimes you just get a bad one.
    they have tried
    207
    I am having a bugger of a time trying to get the servo wire harness out of the receiver opening.
    Aug 2012
    47
    Take out the reciever. It's just held on with two sided tape. That will give you more room.
    207
    Any advice or tricks to doing it?
    Aug 2012
    47
    Stick a small flat head screwdriver under it and pry up.
    Mount Airy, aka "Mayberry" North Carolina
    347
    We gently pulled my receiver loose with a small flat tipped screwdriver
    The Kid
    14.4 Dewalt & Misc. el-cheapo mods
    207
    Quote Originally Posted by rcsickness1 View Post
    Pry what up? The whole receiver box? It doesnt look like i can pull the wires with the harness attached through the tiny slit opening on the receiver. Since this servo is trashed, i could just cut the wires but i still would have to learn how to do it properly when i install the new servo and wire harness.
    347
    You pry the receiver up from the bottom of the box. This will give you the clearance needed to get the connectors in and out.
    The Kid
    Aug 2012
    47
    That little box you have your finger on in the pic. It has the little light on it.
    207
    Not sure how this helps? It doesnt make the slit in the divider any bigger lol
    Aug 2012
    47
    Now pry the reciever out of that box your holding. The reciever has a sticker on it that says Tqi.
    207
    347
    What you are holding is the receiver box with the receiver in it. The receiver can be pried out of the box with a small flat tipped screwdriver. It is only held in the box with doublesided tape.
    The Kid
    207
    Quote Originally Posted by Mayberry Kid View Post
    Oh!!!!!! Hahabababaaha now that makes since lol
    207
    Thank you all for being patient with me hahaha
    207
    Finally, thanks for the help
    Aug 2012
    47
    Good deal!
    Oct 2012
    Perth, Western Australia
    62
    After I removed my Rx I just put a small square of Velcro under it. It makes it much easier next time.
    Only 2984 posts until I'm "allowed" to have an avatar.
    Summit 11/68T 4S 2000kV
    E-Revo 14/56T 6S 2200kV
    Jan 2014
    30
    do you have to take the motor off???
    Jan 2014
    30
    nm i got it
