Thread: 48p to 32p?
    Kentucky
    101
    48p to 32p?
    I'm changing my rustler vxl3s to 32 pitch gears. My question is would a 54t spur an a 19-20 pinion be ok for motor, an not make much heat?
    Worcester, Massachusetts
    1,399
    id start with 17/54 and see what the temps are, what battery are you running
    SL4SH Mamba Monster-Rustler Mamba Max 2400kv
    Kentucky
    101
    Trx 8.4 nimh
    1,399
    19/54 should be fine, watch temps, if its cool, gear up a tooth or 2, if its warm, gear down a tooth or 2
    Kentucky
    101
    K thank you
    14,885
    Wait, what current gearing are you running? There is a way to match up the ratios...
    Example:
    If your running 86/23, your gear ratio is 3.74:1
    Compareable 32p:
    56/15= 3.73:1
    You may be overgeared using a 19t pinion!!!!
    56/19= 2.94:1
    Ya can't polish fertilizer...
