Just got my pede for more than a month, so still newbie, but as i read in diff threads, i already bought some parts to upgrade and replace those weak parts of pede...
just want to know from you guys if i got the right parts and upgrade,.... if its not worth it or if it worth
having it,...
all from traxxas:
.....#6852R Driveshafts, rear, steel-spline constant-velocity (compete asse)(2)
.....#6832X 6061-t6 aluminum caster blocks (blue-anodized)
.....#6860X Motor mount, 6061-t6 aluminum (blue-anodized)
.....#6837X 6061-t6 aluminum steering blocks (blue-anodized)
.....#1952X 6061-t6 aluminum stub axle (blue-anodized)
.....#3767X aluminum shock caps, 4 (red anodized)
.....#1747R blue-anodized aluminum 4mm flanged, serrated lock nuts 4
.....#6893X bearing adapter, 6160-t6 aluminum (blue-anodized)
.....#6877A clear gear cover
.....#6836 Bumper, rear/bumper mount, rear (black)
others:
.....onyx 5000mah 7.4v 25c
.....V6AC Balance charger
.....RPM heavy duty a-arm, rear (black)
next to buy:
.....Velineon vxl-3s esc cooling fan
.....sway bar kit f&r
.....hard-anodized, taflon-coated t6 aluminum shocks, xlong
.....led lightbar(chrome,4 clear lights)
.....6061-t6 aluminum motor plate (blue anodized)
.....anodized aluminum 17mm hex adapters
for now im just bashing through snow, havent try bashing at dry land,...
IMHO, not sure the driveshafts are needed if you stay on 2S LiPo. As for the motor mount and bearing adapter, check out King Headz. The bearing is larger and lasts longer/works better. I used the Traxxas aluminum parts on my Pede 4x4 and love them.
I would get MIP CVD's in the rears if I were you. Expensive, but worth the investment.
Also, get an "outerwears" shroud. Will definitely help get rid of grass, dirt, small rocks, etc from entering the chassis.
im planning to have some 3s too,
and for the kings head? hmmmmm,.....
ok, il check for it,..... thanks!!!!!
so the #6842R ca$60 is not worth it and i should have the MIP than this? hmmmm,....
well thanks,......... i will nxt time,....
and yah. i think i really need the outwears or overtray, cause my pede got snow all over it everytime,....
are the new titanium shafts here yet?
Yes, the MIP CVD's are more worth it.
The outerwears are a very nice "first" mod to do on your part since your using the stampede on snow a lot. You can also check out the JConcepts "Chassis Over Tray" if you want another alternative besides the outerwears shroud.
Oh, the driveshafts are definately needed w/2S LiPo. I kept twisting mine and breaking U-joints on a 4200 NiMh. I've had MIPs on the rear for about 8 months and this weekend the front MIPs will be going in after tearing up one of the Integy XHDs that I had on for about 4 months. Unlike MIP, you can't repair those when they break.
There are a couple of parts that I have broken during my first few runs:
1st mishap: Stub Axle Carriers (Front)
2nd mishap: Golden Horizons Alum Gearbox (Connects to rear lower control arm)
Rear Shock Shafts (Don't forget the shock oil)
Tire glue (Running with LiPo Batteries i.e. Lots of Torque)
Also these part (Better safe then sorry)
RPM Gear Cover Black (Prevents dirt from getting into the gears)
Traxxas Bumper Front Slash TRA5835 (Much better bumper protection for your Stampede)
I have a Stampede VXL
MrTLV
thanks for all of you guys,
overtray,
mip shafts,
kingshead,
some questions again,...
can i use the rear driveshafts in front?
also the a-arm rear? can i use it in the front?
will it fit?
Front and rear arms are the same. For the MIPs you do need a designated front and rear though due to different lengths.
Summit, ERBE X2, 4pdes, 2pdes, etc lol
all from traxxas:
.....#6852R Steel Constant Velocity Shafts, Rear
.....#3340 Velineon Cooling fan VXL-3S ESC
.....#6898 Sway Bar Kit, Front & Rear
.....#6727 Battery Hold Down
.....#2857 POWER CELL 3-cell LIPO, 6400mah, 25c 11.1v
others:
.....RPM heavy duty a-arm front-green
.....RPM heavy duty a-arm rear-green
.....RPM front Shock tower
.....RPM rear Shock tower
.....RPM Wide Front Bumper
.....JConcepts - ILLUZION - overtray
.....3racing Motor heat sink with fan
.....3racing cooling fan (for Exhaust or intake fan on overtray)
.....Dubro Racing Bodyclip retainer
.....GoPro HERO2 Camera With Wi-Fi Combo Kit
Hey guys, Here is an update of what i have now for my pede,...
Still Waiting for my King Headz and Proline Badland tires,
1.? Are the stampede 4x4 and slash 4x4 MIP CVd kit same? will the MIP for slash4x4 fit for pede4x4?
2.? And I need some help with you guys? Cause i dont know how to mount my GoPro cam on my pede? any suggestion? Help?
3.? And i got some problem with my new Traxxas 3s lipo 6400mah, when i am using it, fully charged, when im pulling the throttle slowly like trying to be a crawler my esc blinks red slowly and no more power on my motor, just for the steering, i need to unplug and plug it then green light again, and when i try to pull it slow, red led comes out again, but using it in pull throttle and high speed seems to be ok?
need some help guys,.....![]()
I would give traxxas a phone call and see what they can do for you.but happy to hear that its coming together i will keep an eye on this build....peace
i did contact traxxas via email, and they ask me to sent them my motor and esc for repair and inspection, but it will cost me $100, and? i will be out on bashing for long, so i am still looking for any help that will not need sending my motor and esc to traxxas,
And next thing to do is make an account on photobucket so i can show and share my pede with you guys,....
I would have to retract my statement about the stock driveshafts. I put Proline Trenchers on my truck and on the 3rd run, snapped an axle! I just out another stock one on it for now until I can fund the MIP's.
If your slipper clutch is PROPERLY set up, you do not need upgrade driveshafts.....PERIOD!
"RED"
Like....<extra text to make post long enough to submit>......
That is one sweet pede dude.....peace
What's the "C" rating on the battery. Some people will say it doesn't matter, but I had a boat load of problems with a 20C. Swapped it out for a 30C and it's worked perfectly every since.
Also check your connector to make sure you are making good contact. I have a Venom battery that is arcing. Will be buying a Traxxas connector from LHS soon.
Happy Bashing!
Bash'em, then Bash'em, then Bash'em some more!!
Yeah should work. Check to make sure connector is solid and not arching.
all from traxxas:
others:
.....MIP X-DUTY CVD Front axle kit #10132 (slash 4x4)
.....MIP X-DUTY CVD Rear axle kit #10130 (slash 4x4)
.....INTEGY LiPo Voltage Checker + Warning Buzzer
.....APS Stainless Steel Screws Set
before
after
Its nice to see another bulletproof pede coming alive dude keep up the good work and keep us posted...peace
before (Traxxas steel constant velocity shafts
after MIP CVD X-Duty Shafts, F/R
i did some DIY for my pede, exhaust or intake fan installed with my over tray, no connector to be connect or disconnect, simple put your overtray and the fan will work.
im not sure if my connectors connection are solid, i dont know if its jamming or not?![]()
In the summer try and get as much cool air in as possible dude to stop it going into shut down maybe look at the mega fan the guys have done....peace
If you dont have a dremel just use a small hacksaw it will do the same job but with a bit more effort dude......peace
just received from mail, mega heat sink with mega fan,huge,.....
also i bought the alum STRC steering Bellcranks, and revo spec slipper clutch,....
and my 1st ever, dremel,....... ill be sleeping late tonight to do some mods,.....
start with the slipper clutch,....
need help, pressure plate rubbing with the bulkhead, what did i missed? what is wrong?
Did you move the pin to the "other" hole? The one closest to the pressure plate? With exception of the driveshaft yoke/outdrive on the right of the pic (I'm running a Tekno driveshaft), it should look exactly like this following revo-spec mod (note last pin-hole to the left of the pic is vacant):
Someone stole my signature.
yes i did, but still it touches the bulkhead
Post a side pic.
here
the traxxas steel constant shafts works great, but in some point they also have great weakness, pins doesnt have any hex screw, only rubber cover holds them, once the rubber pops up, game is over for the shafts
Just disassembled mine. It rubs a little on each side when not braced/supported by the other. Does it rub when connected to the driveshaft and chassis?
