Page 3 of 15 FirstFirst 1234513 ... LastLast
Results 81 to 120 of 594
  1. #81
    Wales in the UK
    6,462
    Any updates on the esc dude???..........peace
  2. #82
    Alberta Canada
    562
    Just got my new esc. Ezrun 120A WP sc8.
    My spare system.
    sent from my Galaxy S4
  3. #83
    Wales in the UK
    6,462
    Awesome esc dude and look into the program card its worth its weight in gold and take it with you when you go bashing..........peace
  4. #84
    Aug 2013
    Southern MS
    67
    Is that a different fan on your motor heatsink? If it is where did you find a replacement?
  5. #85
    May 2013
    Concord,NH
    70
    i love the wp sc8! great choice!
  6. #86
    Alberta Canada
    562
    Yeah. I figured out that i really need to have the program card. For better bashing.
    As a review for this esc it has more power. More sensitive than vxl. Can handle more of 3s.
    Same time more cogging than vxl on low speed.
    Quote Originally Posted by ewalker302 View Post
    No its thesame fan. But i bought another heatsink from ebay hobbywing and ask to have a spare fan together.
    Quote Originally Posted by T4KT1KZ View Post
    Ya i learned that lesson the hard way too. Luckily i was able to sell the vxl combo out of my slash before i killed it aswell. I upgraded my p4de to the hobbywing wpsc8 when it died, I liked it so much i bought a second one for my slash. But if you are upgrading the esc you should look at upgrading the motor too.. the castle 2400 is boss.. but recently i picked up a losi 2800kv motor out of a ten-t and it is basically identical to a 2400kv. Both are made by castle... i picked it up for 49.99 + 6.99 shipping..
    Yeah. I can say that this esc vs this motor. Motor wont last long. Thanks for the info. Maybe after frying this two motors i have. Hehe. Or sooner to save some velineon motor here....
    And any help guys for this new esc. Im not use to it. Reverse power is too slow. And reverse doesnt have brake. When im running reverse and then hit brake. Its just throttle forward. Feel lazy too see the manual
  7. #87
    Jul 2013
    Vancouver B.C.
    569
    I would go in a check the programming on the ESC. Its all in the manual which you can find on the Hobbywing Website
    http://www.hobbywing.com/uploadfiles...W-13-WP-SC.pdf
    Item # 1 Should be set to value 2 as Default. (Everything in black is the default setting) I would start by double checking that as maybe it was accidentally changed.
    I have the LCD Program Box, and it is a must have.. Smaller then i thought it would be. Slightly bigger then a pack of cards.
  8. #88
    Alberta Canada
    562
    Thanks. Yeah i just orderd the lcd program box. Just a question. How can i go with this programmable items.
    And with the item no. 1. Value 2? Is there any or same settings as the vxl. Same forward brake reverse brake all single click.
  9. #89
    Jul 2013
    Vancouver B.C.
    569
    Quote Originally Posted by janmichael_zamora View Post
    I dont understand what you mean. I would recommend reading through the manual for the sc8
    on page three it shows a programming tree. You can program any setting you want on the SC8 simply by following the manuals instructions and counting LED flashes ETC. No Program box required.
    Hope this helps.
    Item 1 has three differerent values you can set.
    1 = Forward only. with brake (for racing Reverse is locked out) like sport mode for vxl Mode 2
    2 = Forward, brake and reverse (like VXL Mode 1)
    3 = Forward and reverse only. No brakes . For crawlers...
    It should be set to 2.
    Also you commented that your reverse was slow.. Its because its limited to only 25% as default.
    Item 6 Adjusts that.
    I set mine to only 50% as im not into going super fast in reverse... But if you want 100% power in reverse set Item 6 to 4 (be carful as 60MPH in reverse is scary LOL..)
  10. #90
    Alberta Canada
    562
    But no.2 doesnt have brake on reverse right. When you move the throttle from reverse to forward zone the truck will go forward immediately? Not same as vxl?
  11. #91
    Jul 2013
    Vancouver B.C.
    569
    Good question.!. Im not sure if has brakes in Reverse... I would think it does... but to be honest im not sure..
    I dont usually brake in reverse. LOL
    But I will check it out next time I run mine.
    Now that i think about it... I dont think it does have brake in reverse. One of the things i do often with my truck is reverse 180's. When im pinned in a corner and I have to back out.. I go full reverse 180 to full forward.. and it does Rockfords like a champ.. Leading me to believe it does not have a brake while travelling in reverse.. Ill double check tomorrow..But then when i think about it...
    Does the VXL actually brake while travelling in reverse??? Because I seem to remember doing them with the stock system as well..
    Hopefully someone elsecan chime in here and explain the differences between the two..
  12. #92
    Alberta Canada
    562
    Yeah it does have brake from reverse. Maybe ill get use to this esc sooner. More bashing for me and my pede and be connected again as before.
    And for the programmable item i didnt saw at first that its writen
    .......the following steps are just like the above items......
    Haha.... they cut the whole program patern and mislead me.
    Need some help here. Anyway to fix this? Need something to hold my battery down.....
  13. #93
    Wales in the UK
    6,462
    Drill out the old screw and put a bolt with a flat head up through the bottom of the chassis and put a nut on it and then drill two small holes in the bolt and job done dudeOr something like my idea LOL............peace
  14. #94
    Alberta Canada
    562
    Thanks. You gave me an idea. Hehehe. I just drilled the old screw out. And filled the hole with adhesive let it dry. And then drill again same size. And bought a battery holddown kit. Again.
    Good as nothing happend.
    Got the multifunction lcd program box.
  15. #95
    RC Champion soundmaster's Avatar
    2,858
    Nice dude!
  16. #96
    Wales in the UK
    6,462
    I love my program card and take it with me every bash sessionAnd I am glad your battery post is now fixed dude............peace
  17. #97
    Alberta Canada
    562
    Yeah. Tnx dude....
    Snow is here again.
    So i'm planning to get some extra grip for my pede so i can have have eztra snowbashing time.
  18. #98
    Jul 2013
    Vancouver B.C.
    569
    Snow is here again.
    I'm on the fence about locking the diffs in my trucks. I did it a few times in my 2wd to really get a feel for it.
    In anything but a crawler or a drifter it is going to impact performance quite a bit. It was still fun for a while tho the truck did doughnuts like crazy.. Haven't tried it in any of my 4wd's so let us know how it go's.
    You may find the performance you are looking for by simply switching to a really heavy weight differential fluid. 100k or above..
  19. #99
    Alberta Canada
    562
    Oh. I already ordered the locking diffs. But i think ill be using it first only at the front.
  20. #100
    Jul 2013
    Vancouver B.C.
    569
    Let us know how it go's. I know in my two wheel drive it made it a lot harder to control not sure how a locked diff would affect your steering at speeds so let us know how you make out with it..
  21. #101
    Wales in the UK
    6,462
    I would go for heavier diff oil first like 100k front and 50-60k in the rear before you lock them .....peace
  22. #102
    Alberta Canada
    562
    I will be using the locking diffs just for snow bashing so i could get more grip and traction. Cause i need to have more traction than control over the snow.
    Haha. i just put together all my spare parts and looks like i have a new build. With wooden chopsticks parts.
  23. #103
    Jul 2013
    Northern Norway
    870
    Ha, ha, ha!
    It seems someone has too much spare time on hand.
  24. #104
    Alberta Canada
    562
    Quote Originally Posted by Viking View Post
    Ha, ha, ha!
    Yeah. And i was like laughing the whole time im making this mods. Haahahaha....
  25. #105
    Jul 2013
    Vancouver B.C.
    569
    Thanks for the laugh!.
  26. #106
    Alberta Canada
    562
    Guys need some help here to decide. Which of this two servo is a better replacement for the stock one. Which and why?
    Or any better servo thats waterproof and wont brake the bank. $80max
  27. #107
    May 2013
    Concord,NH
    70
    i got a question, when i JUST BARELY touch the a wheel then give it throttle the wheel wont move... front and rear. is it my diffs? also its not the hexes lol
  28. #108
    Alberta Canada
    562
    Quote Originally Posted by waya7 View Post
    I dont get it.
  29. #109
    May 2013
    Concord,NH
    70
    this is what i am talking about :P sorry it is confusing...
  30. #110
    Jul 2013
    Vancouver B.C.
    569
    To me that just sounds like the four pole motor moving back and forth no?
  31. #111
    Alberta Canada
    562
    Its sounds like your diffs gears at the front are having some problem.
  32. #112
    May 2013
    Concord,NH
    70
    yes, the noise is my 4 polo motor but i am talking about the wheels stop moving :P
  33. #113
    Jul 2013
    Vancouver B.C.
    569
    I'm sorry but I have no idea what you're asking... What is the problem exactly?
    One thing I did notice when I put my truck back together is if you torque this screws down too tight into the diff it would cause it to bind in one spot every revolution I found just slacking off to screws a quarter-turn solve the problem
  34. #114
    RC Champion No One's Avatar
    May 2005
    Minnesota
    1,186
    What happens when you separate the gearing at the motor?
    Slash 4x4
    Stampede 4x4
    Stampede 2WD
  35. #115
    May 2013
    Concord,NH
    70
    okay i am really sorry i am making this so confusing lol okay, what i am saying as simple as i can say it is,
    see in the video, when the wheels are off the ground, they turn in different directions. and when i touch one wheel it stops moving so only one turns. is it supposed to do that, or do i need thicker diff grease...
  36. #116
    Jul 2013
    Vancouver B.C.
    569
    Totally normal
    Totally normal
    all thicker differential oil is going to do is stiffen up the diffs. Locking the diffs in anything other than a drifter or rock crawler will impact performance.
  37. #117
    Alberta Canada
    562
    Just got my locking diffs. Hope itll help to get more grip and traction for my pedes snowbashing
  38. #118
    Jul 2013
    Vancouver B.C.
    569
    Nice! Let us know how they work out
    I haven't had the chance to drive my truck in snow yet
  39. #119
    Alberta Canada
    562
    its like??????? L
    Thick snow. like bashing on a park with tall grasses
    Thin snow. like bashing on a wet muddy surface.
    And crystalized ice. like driving on oiled glass. Haha. No traction at all. Like drifting i gues
    And can anyone help me with this servos. I dont know witch is better. And if it will fit my pede.
  40. #120
    Jul 2013
    Northern Norway
    870
    They will both fit. However, you can not use the stock servo arm because the stock servo (2075) has a 25T spline whereas the Hitec's have 24T.
    The HS-646WP is analog and not much of an upgrade besides the metal gears. The HS-5646WP is digital (as the 2075), has metal gears and is 25% stronger than the stock servo. But it is not a faster servo.
    So my vote goes to the HS-5646WP.
