Page 6 of 15 FirstFirst ... 45678 ... LastLast
Results 201 to 240 of 594
  1. #201
    RC Champion soundmaster's Avatar
    2,858
    Quote Originally Posted by janmichael_zamora View Post
    Ahaaaaa..... my first shoegoooodd body.... hehehe..... iwant this mj grave digger body to last longer than my stock and my raptor body..... so gonna give this a try......
    Sent from my SGH-I337M using Tapatalk
    Good job !!!
  2. #202
    Alberta Canada
    562
    Thanks......
    Sent from my SM-T310 using Tapatalk
    Ok. So summer is coming and this is my p4des power system....
    im running a hobbywing ezrun 120a waterproof. And the stock velineon 3500 motor..... and always on 3s lipo.... now i know this motor will be fried if i will not upgrade it..... so i need your help guys to decide what motor will work for me.
    I want it/with
    waterproof
    Power
    Speed
    No heat issue
    compatible with this esc
    Fun
    Fun
    Fun
    Fun
    :beer:
  3. #203
    2,858
    Castle 1415 2400kv!!!!!!!!!!!!!
    You can get it cheap from stripped Funny Car.
    I run it on 3s and 4s with the same esc as you (hw sc-wp8) and it really rocks dude
    You have to do a little dremel job on the chassis though.
  4. #204
    Alberta Canada
    562
    Its colored blue by traxxas so its a waterproof?
    Velineon 3500 is a 3500kv motor
    Castle 1415 is a 2400kv motor
    So which of these two will give my p4de more speed and more power or torque.... and how?
    :what::what:
    Well i know that 2400 will. But i want to know how? Can somebody explain how this things work?
  5. #205
    2,858
    :what::what:
    First of all it's a 4 pole, Velineon is a 2 pole and it is much longer too. Check out my foto:
    This Motor is strong enough for moving around my Summit at about double the speed as the titan 775 without any heat issues (stock gearing 4s Lipo). I had it installed for a couple of runs. Now it is back in my 4s powered Stampede 4x4 geared for about 45 mph for some serious bashing.
  6. #206
    Alberta Canada
    562
    Thanks dude..... and thanks for the photo. I can use it for future reference on how to make them fit with my p4de.
    So a 4pole motor is like 4cylinder engine. Even tho its not a high speed engine it can produce high torque.... so in that case you can gear the pinion higher. That makes the truck faster? Am i right?
  7. #207
    Feb 2014
    607
    Higher pinion gear more top speed higher motor temps
  8. #208
    2,858
    The lower the KV the motor has the higher you can gear.
    But also you need more voltage to get a good performance. The Castle 1415 2400kv is good for 3s and 4s but not for 2s eg.
  9. #209
    Alberta Canada
    562
    Quote Originally Posted by Pede4x4owner View Post
    Ok. But 2pole compare to 4pole? 2pole will produce more heat if run with higher pinion than 4pole?
  10. #210
    Feb 2014
    607
    4 pole means there's 4 magnets on the shaft inside the motor
  11. #211
    Alberta Canada
    562
    Yup. Iknow. But 4pole more magnets more electromagnet reaction and more torque? More torque that can spin bigger pinion but will produce less heat because it made for torque?
  12. #212
    Feb 2014
    607
    Bigger pinion is not made for torque it's made for more top speed equals more amps which will run hotter.
  13. #213
    Alberta Canada
    562
    Ok. So 2400 kv motor 4pole will run hotter with high pinion than a 3500kv motor 2pole on normal gearing? So why 2400 can run faster? Cooler?and gives more torque than 3500?
  14. #214
    Feb 2014
    607
    2400kv don't really need a higher pinion to go fast because u can run a higher cell battery like a 3s or 4s which is crazy power.
  15. #215
    Alberta Canada
    562
    I am using 3s lipo on my p4de everytime. So which will be faster?
    3500kv or 2400kv? Lets say running with stock gearing?
  16. #216
    Feb 2014
    607
    2400kv stock gears with a good 3s lipo should be faster. 4s would be uncontrollable crazy fast.
  17. #217
    Alberta Canada
    562
    Ok so what does kv means on BL motor?
  18. #218
    Feb 2014
    607
    The letters kV stand for the the RPM of your motor per volt with no load.
  19. #219
    Alberta Canada
    562
    Hmmmm. Ok. So
    2400kv x 11.1 =26640
    3500kv x 11.1 =38850
  20. #220
    Feb 2014
    607
    2400kv will run way cooler and the ability to run 4s. U could up the pinion a few teeth and still run cool, the 3500kv is gonna run hot on 3s after 10-15 mins usually.
  21. #221
    Alberta Canada
    562
    Yup. But the calculation shows that 3500 can make higher rpm than 2400. So how 2400 can go faster if it can only make less rpm?
  22. #222
    Feb 2014
    607
    Either a 4 cell lipo or a higher tooth pinion there's a guy on here running a 23t pinion with a 2400kv. U would burn the motor if it was the 3500kv with that size of pinion. There's a thread about it
  23. #223
    Alberta Canada
    562
    3500x11.1=38850
    2400x14.8=35520
    Still 3500kv motor will make higher rpm with 3s than 2400kv motor on 4s.
    3500x11.1=38850
    2400x14.8=35520
    So to make this 2400kv motor faster than 3500kv motor it really needs a higher pinion? Am i right?
  24. #224
    Feb 2014
    607
    Ok but the 3500kv can't handle higher pinion teeth that the 2400kv can which means the 2400kv motor will run faster.
  25. #225
    Alberta Canada
    562
    So its normal for 2400kv to motor to use higher pinion. And temp wont be that much issue compare to 3500kv?
  26. #226
    Feb 2014
    607
    Correct sir
  27. #227
    Alberta Canada
    562
    And 3500kv motor is a high speed motor. But Less torque than 2400kv. It can go faster but needs to stay on low pinion to produce higher rpm. But highspeed running makes its so hot?
  28. #228
    Rotterdam, Netherlands
    8,617
    Don't be fooled by Kv ratings. They tell nothing about power. They say what rpm your motor wants to run per volt, not if it will.
    Under load everything changes. You need power to make those rpm when it's working to get your car ahead.
    The 3500 compared with the 2400 will make more rpm per volt, but it's not even close as powerful. To transfer the power into speed in your car, you need the right gearing. The 2400 can handle a bigger poinion/smaller spur than the 3500.
  29. #229
    Alberta Canada
    562
    Thanks..... 2400kv motor is really the way to go. It has speed and torque at thesame time that will push the truck much more than stock motor with lower temp.
  30. #230
    Wales in the UK
    6,462
    That's why I have a happy medium setup my 550 4 pole 3500kv tenshock motor running a 17t pinion on 2s and 3s but I would love 2400kv......peace
  31. #231
    Alberta Canada
    562
    Just ordered the castle creation 2400kv motor for $70.....
    And hows a 3500kv 4 pole motor on your p4de dude?
  32. #232
    2,858
    Man thats a great deal. I am not going to say what I payed for this motor here in Europe
  33. #233
    Alberta Canada
    562
    Quote Originally Posted by soundmaster View Post
    Haha,..... i paid $15 for shipping to canada. How much more to you,.....???
    Btw dude,..... i gues no body answerd my question,.....
    Is this motor waterproof?
  34. #234
    Wales in the UK
    6,462
    My tenshock motor is just pure speed and torque dude I don't think I would ever go bigger than the castle 2400kv because there would be no need for me.....peace
  35. #235
    Alberta Canada
    562
    Yeah i gues the 2400 will over power my p4de.... but i think it will be alot of fun..... so its ok.... thanks dude.....
    Is this 2400kv from castle waterproof????
  36. #236
    8,617
    Except for risk of rusted bearings, most brushless motors are waterproof.
  37. #237
    Alberta Canada
    562
    Big thanks for that..... so i can shower it every after bashing like my velineon motor?
  38. #238
    8,617
    As long as you blow it dry and keep the bearings lubed.
  39. #239
    Alberta Canada
    562
    Ok. I always lubed my p4de after shower even with the velineon so i can do that on my next motor too.... thanks.....
  40. #240
    2,858
    The only RC that I shower is my SCX10 Rubicon but never my Stampede 4x4 and Summit
