Page 7 of 15 FirstFirst ... 56789 ... LastLast
Results 241 to 280 of 594
  1. #241
    Alberta Canada
    562
    Quote Originally Posted by soundmaster View Post
    The only RC that I shower is my SCX10 Rubicon but never my Stampede 4x4 and Summit
    I sleep with my p4de everynight so i really need to shower her...... haha......:beer:
    Sent from my SGH-I337M using Tapatalk
  2. #242
    Feb 2014
    607
    What do y'all lube after shower ? Lol I just wipe mine down
  3. #243
    Feb 2014
    607
    The pede not anything else post sounds dirty my bad !
  4. #244
    Alberta Canada
    562
    Im just using multi purpose oil. Just lil bit on every joints and moving parts.
  5. #245
    Feb 2014
    607
    WD40?
  6. #246
    Alberta Canada
    562
    Nope. But some guys here are using wd40 for their p4de.
  7. #247
    Lafayette,LA.
    712
    My tenshock motor is just pure speed and torque dude I don't think I would ever go bigger than the castle 2400kv because there would be no need for me.....peace
    Speenie, I see you mention that motor/ESC a lot man. I'm going check it out dude. I've got two 2400s sitting in a drawer lol.
    Sent from my MB886 using Tapatalk
  8. #248
    Feb 2014
    607
    Doesn't he run the HW esc ?
  9. #249
    Wales in the UK
    6,462
    Yeah I run the hobbywing sct pro 120a esc and tenshock sc411 3500kv 550 four pole motor on 2s and 3s geared 17t pinion and 54t spur and highest temps have 140-147f with dirt hawgs on 2.8" desperados and it's a little monster........peace
  10. #250
    Feb 2014
    607
    Easy install ? No modifying ?
  11. #251
    Wales in the UK
    6,462
    I had to do some dremel work but apart from that it was a straight forward installation dude ......peace
  12. #252
    Alberta Canada
    562
    I will miss bashing with my p4de.....
    just bash and learn baby......
  13. #253
    Wales in the UK
    6,462
    Why is that dude????.......peace
  14. #254
    Alberta Canada
    562
    Cause I'll be leaving for more than a month.... goin for a vacation......
    While waiting for my 2400kv motor and my tekno big bone center drive shaft im thingking what gearing ill be using..... so i need help again guys..... i have a 17pinion here. Will this work fine? Speed. Torque. And temp? Ill be using stock spur gear btw.
  15. #255
    Feb 2014
    607
    Yeah 17t would be good and low temp for that motor u could even go as high as 23t
  16. #256
    RC Champion soundmaster's Avatar
    2,858
    I run 14/54 on 3 and 4s for extreme offroading.
  17. #257
    Alberta Canada
    562
    Hows the temp and speed with 14t pinion?
  18. #258
    2,858
    Quote Originally Posted by janmichael_zamora View Post
    My Stampede is pretty heavy about 7 lbs and also I run in grass and very rought terrain all the time and I run bigger tires (trenchers) than stock so 14t is perfekt for me. Speed is more than you'll ever need in this kind of terrain and temps always below 150F.
    I also jump a lot. Backflips, double backflips and all this crazy stuff. Much stop and go stuff too and I closed down my slipper all the way for wheelies and more punch.
    But you'll need 17mm Adapters, Stronger axles, and stronger rear diff. With this power, weight, grip and drving style these parts will break very soon.
  19. #259
    Alberta Canada
    562
    Thanks.... and about esc with this motor? How did you install it? I dont have the motor yet but i want to start moding esc s mount while waiting...
    But you'll need 17mm Adapters, Stronger axles, and stronger rear diff. These parts will break sooner or later.
    Yeah..... i already made my rear and front diff stronger and also planning to get thwle aluminum one. And also. Next will be 17mm adapters and khz motor mount.
  20. #260
    2,858
    I used a dremel to create space and then build a socket were I mounted the esc with strong double sided mounting tape. Very easy to do
  21. #261
    Alberta Canada
    562
    Do you have some pic of it installed? I know we have same esc so it will be perfect....
  22. #262
    2,858
    You got PM!
  23. #263
    Alberta Canada
    562
    You got PM!
    Thanks dude.....
    Tonight i will start the mod.....
    Snow bashing is over for now.... took off tirechains put it in a plastic with lil oil......
    I miss seing this mashers without chain....
    2400kv 4pole BL motor from traxxas funnycar installed..... and esc mount mod done..... just waiting for the tekno bigbone center drive shaft and kingheads motormount.......
  24. #264
    Wales in the UK
    6,462
    Dude your truck is going to be tough as nails and very fast indeednice work...........peace
  25. #265
    Feb 2014
    607
    Nice what esc is that ? Hw 120a ?
  26. #266
    Wales in the UK
    6,462
    Yeah its the hobbywing sc8 120a esc .......peace
  27. #267
    Feb 2014
    607
    I really want one. So there's no different gauge wire between 1/10 scale and 1/8 scale motors ? I've seen that esc on both that's why I ask.
  28. #268
    Wales in the UK
    6,462
    They are a good esc for the cash and can handle 4s a treat and no the gauge of wire it comes with is more than plenty to power most brushless motors dude.......peace
  29. #269
    Feb 2014
    607
    So same size plugs right in ? 2400kv even a 3500kv? Just making sure !
  30. #270
    Wales in the UK
    6,462
    Yeah dude and long as the bullet connectors off the motor are the same sizejob done.....peace
  31. #271
    Feb 2014
    607
    Are they usually ?
  32. #272
    Wales in the UK
    6,462
    There are a few different sizes I used 4mm castle ones on my setup but the vxl system uses 3.5mm.....peace
  33. #273
    Feb 2014
    607
    How do u switch them out if need too ?
  34. #274
    Alberta Canada
    562
    Quote Originally Posted by Pede4x4owner View Post
    Yup....
    Thanks.....
    got this tekno bigbone and intalled it......
    looks great..... i like it.... just did some mod... because i cant put the bearing in.so need to dremmel the top of the grub screw..... now i can just slide yje bearing inside out without taking off the tekno output shaft....
    my 1st run with my 2400kv motor.... and i need help....
    im running it with sc8 hobbywing esc.
    and it feels like it l is cogging too much..is it normal? and having some trouble meshing my pinion and spur gear..... cause of 4pole motor....
  35. #275
    Feb 2014
    607
    It shouldn't cog if it's a 4 pole sensored motor unless the esc isn't sensored. 4 pole gear mesh sounds different from a stock motor setup also.
  36. #276
    Alberta Canada
    562
    its not a sensored motor and esc....
  37. #277
    Feb 2014
    607
    Non sensored there gonna have some cogging
  38. #278
    2,858
    use the double paperstrip method to set gear mesh.
    as you know i have the same combo. gearing 14/54
    also i set timing on esc to 0. mine is not cogging much. i can run it pretty slow. slower than walking speed.
    litte cogging is normal, but if you are used to sensored bl or brushed motors there is some change.
  39. #279
    Alberta Canada
    562
    ok so setting the timing to 0 will make the cogging less.....?
    i can only set my escs timing to 1. i dont have 0 option for it.... but it still cogging too much.... i am used to the vxl cogging but this sounds too much...
  40. #280
    Feb 2014
    607
    Is your slipper clutch tight ? If it don't slip as much it won't cog as much.
