Results 1 to 3 of 3
    walkertown,nc
    127
    brushless motors
    how do you tell what the horse power and torque curve of a brushless electric motor is?what does the kv rating stand for?
    anyone have an extra truck,I broke mine again
    667
    Quote Originally Posted by troylynch View Post
    i believe the HP and torque curves of a BL motor are would be exponential. id have to go look it up to be sure though. KV is rating of rpm per volt. 1000KV at 6v is 6000RPM.
    Sent from my Transformer using Tapatalk 2
    recalculating...
    590
    a lot of motors will have a power rating in watts listed in the specs,1 hp = 745.69 watts as a conversion factor. I think technically the best way to measure power from a motor is to actually measure how many amps were drawn from the motor, it's easy to look at theoretical specs and assume your 9000kv motor will make 5 HP and should take you 100+ MPH, when in reality it will simply overheat.
    I like turtles.
