I am currently running a 15/40 setup. When I changed out my motor and reinstalled clutchbell. I have some play at the end if the crankshaft between clutchbell and retainer clip. Is this normal or should it be tight at the clip? Ivan move it about a 1/16th back and forth. Didn't know if I had missed a piece. Also my ez start sometimes slips while spinning after reinstalling. Never did that before.
Take your ez start back off and clean the one-way bearing. Clean it real good, re-oil it with some light oil, reinstall. My bells have some play but I dont think its a 1/16th of an inch. Ill look tonight and see.
One shot.....One kill, no exceptions
is it possible that you forgot your washer?
I'll pull off ezstart and check owb tonight. And i need to pull up exploded view and make sure I'm not missing something. Thought I had it all. Thanks guys!!!
Check for Teflon washer or you might have to use another washer between block bearing and the cone.
Ok thanks 67. I got tied up changing driveshaft boots. Gonna pull motor tonight and check cb.
