Results 1 to 22 of 22
    126
    Best type of brushless motor and gear setup for brushless
    I'm planning on buying a brushless setup this tax return season. I'm lookin for a brushless motor and gear setup that will work with said brushless motor. I want a setup where I can do nonstop wheelies and stand still backflips but still be able to have fun in the dirt and water. Any suggestions for brushless motors and gear setups? Thanks for your time.
    9,244
    If your talking for a maxx you will have to upgrade your diffs for back flips
    Probably use the 2200 with the Mamba monster 2 esc
    muscoda, wi
    1,245
    you wanna wheelie like this dont you. lol
    http://www.youtube.com/watch?v=4ifA_H402Nk
    im running a hobbywing 150amp sensored esc/1800kv sensored motor. that is only 4s on 20t pinion, stock spur. it does take 6s. so im thinking it would be easy to back flip it. the motor/esc is 189 on flebay. mine came with a program card to set up esc functions. plus i can do it online similer to castle. the esc is water resistant, but not waterproof. i will be using a dusty motors cover so im good to go. peace.
    Jacksonville, Fl
    628
    the mamba monster 2200kv motor is NOT waterproof, castle creations only came out with a waterproof ESC, not a motor. mamba monster 2200kv will be out of the question if you want to play in the water.
    EMBE
    Jato 3.3
    T-Maxx 2.5
    4,873
    most brushless motors are waterproof or should i say wont get damaged when hitting water but if its freezing water and your motor is like running 140+ then you may have a problem. I know my motor i can get it wet which is a hobbywing xerun 2000kv motor, you just need to make sure the water is drained out before running again next time.
    Living life.
    126
    Something like this for example. http://youtu.be/85fGW5aoRdQ
    muscoda, wi
    1,245
    Quote Originally Posted by Crzyjeff View Post
    i have that 120 amp esc also. well i actually have the new waterproof one. im just searching for that 2700kv motor. sweet e-maxx vid.
    126
    I may just spend the extra money and get a mamba monster 2 combo. For a 2650kv motor with 4s on a mamba monster what gearing would I need?
    4,873
    The 2650 motor is meant for a little lighter truck than the emaxx. I would go for the 2200 instead. The 2700 ezrun motor from hobbywing is good but you have to gear too far down and there for loss the benefit of the higher kV motor and its a max of 4s only when the 2200 is 6s which in turn will run cooler because of the lower kV.
    I also have the 120wp ESC from hobbywing in my emaxx and runs cool with my 2000kv motor 4s geared 21/65. Content with that for now.
    Living life.
    Dec 2007
    Manassas, Va
    7,167
    i run the 2650 in my Revo and it runs great in it. I actually prefer it over the 2200. it's got gobs of torque and plenty of speed on 4S. no issues with temps either. I like to run 62/22 for gearing. hope that helps!
    One mans garbage is another mans ungarbage" -Ricky
    4,873
    Is not the erevo lighter than the emaxx? I can gear way up than what I am at right 21/65 to like 24/65 or even 24/58 if it could fit and temps would be around 150-160 motor and ESC maybe 140 it runs way cool with the fan always on which is default on hobbywing.
    Living life.
    muscoda, wi
    1,245
    i do want the new castle waterproof esc, and a 2200 for another project.
    9,244
    My maxx is a few pounds heavier then my revo. But it has trenchers and my revo has badlands
    126
    I'm probably going to get the mamba monster 2, 2200kv combo then. Cause I would get the hobbywing sc8 waterproof combo with a 2000kv but the only place it seems I can find them are on eBay and the sellers on eBay don't have consistent accurate photos of the waterproof ESC and they all ship from Hong Kong.
    518
    I have a hobbywing 150amp esc tacon 2150kv motor It works great. I want to try a sensored setup next the xerun 120amp v3 with a gforce 4074 2650kv motor on 4s this will be a onroad setup
    4,873
    Quote Originally Posted by momort View Post
    your first setup is good. the second setup your talking about would be ok but you understand that is a high KV motor though with the right gearing.
    Living life.
    518
    I just notice that the v3 only supports 3s. So im going. To gear up my current. Setup with 2 2s lipos 70c discharger
    43
    When it comes to simplicity of use, easy to find/buy, quick shipping and great customer support, its really hard to beat Castle equipment pound for pound. Especially when you can find sites when they are around $250 w Traxxas connectors already installed.
    JMO
    4,873
    Yeah gearing up helps just watch those temps. I have 21/65 but a 2000kv motor doesn't get hot for nonstop running 30-40 mins. More like 24/65 or 24/58 if it will fit might see temps of around 145-155 maybe. 70c is a lot of amps in those if there are rated right!
    Living life.
    518
    I was going for
    26/68. With proline road rage tires
    9,244
    Have you done a kv speed test to see how close the free revo kv is?
    4,873
    26? I know pinions are easier to replace than spurs that's for sure. I have an assortment of spur gears now doubles on all lol. Need more pinions you should get a good top end with that pretty much near max have you thought about 24/65?
    Living life.
