    Royersford, Pa
    542
    XO-1 KNUCKLES, Front steering & rear carriers
    Quick question, can the XO-1 KNUCKLES, Front steering & rear carriers be used on the slash 4x4 w/ the stock axles?
    Thanks!
    STRC Slash 4x4
    Hobby Hut Raceway, Audubon Pa.
    7,264
    No, the XO-1 uses 6mm stub axle while the slash 4x4 have 5mm. although if you buy all the XO-1 driveshafts along with those knuckles, then yes it will work, but here a thing about it, you have to use the 17mm hexes or buy the tekno M6 12mm hexes.
    Royersford, Pa
    542
    Thanks! thats kinda what i was thinking but i wasnt sure
    STRC Slash 4x4
    7,264
    no problem.
    Sep 2012
    173
    Yes, you CAN use the XO-1 parts on the slash with the stock axles. All you would need is (6) six 5x12x4 bearings instead of the 5x11x4 bearings. It would actually be a slight upgrade since the actual ball bearings inside will be slightly larger.
