Results 1 to 37 of 37
    105
    Question Waterproof single servo???
    Any recomendations?
    12,314
    I don't know of any waterproof ones... my BlueBird 35A has o-rings at every seam, but is not labeled as waterproof.
    It is extremely easy to waterproof a servo... only took me maybe all of 5 minutes to waterproof my other servo.
    I disassemble the servo, put a glob of grease at the servo horn, smear some RTV at the seams and reassemble.
    Perth, Western Australia
    62
    As Jimmie said regards waterproofing.
    I have my second one of these on its way:
    http://www.ebay.com.au/itm/350679154...#ht_2584wt_970
    Summit 11/68T 4S 2000kV
    E-Revo 14/56T 6S 2200kV
    62
    75
    i'm looking for one as well
    the middle of nowhere
    419
    Like Jimmies's bluebird, my futaba S9157 has O rings around the seams, under the screw heads that hold it together, and one around the output shaft. Also like the bluebird it is labeled "water resistant" on futabas site...not water proof.
    Central Texas
    18
    I installed a Bluebird without sealing the seams as I never intended to run in water. On the first trip out with the new servo i did a back-flip off a ledge into a creek. I pulled it out immediatly but was too late. it shorted within five minutes. I opened it up when I got home and it had a lot of water in it. I dried it but it was toast. My own fault...I was happy with the power of the servo in the short time that I used it.
    75
    I might just get a savox and wp it myself
    12,314
    The BlueBird 630 is too weak to go with just one servo at 195in-oz... stock is 125 each with 250 total torque.
    75
    Would the 660 be ok? Torque At 6.0V: 14.2kg/cm , 190 oz/in still under the 250 total of stock setup I see.
    or theres
    L530DMG Torque At 6.0V: 24.3kg/cm , 348 oz/in
    860DMAX+HS Torque At 6.0V: 23.2kg/cm , 322 oz/in
    12,314
    Quote Originally Posted by DayWalker View Post
    or theres
    Any of those will work.
    I suggest a target torque of 300-350... anything over 350 is going to overpower the stock servo saver.
    (Not saying don't go over, but I wouldn't pay extra for it)
    Central Texas
    18
    The Bluebird 35A had good power. I will waterproof the next one even though I don't plan on getting it wet.
    75
    35A looks tough I assume you run a bec for that? I didn't really want to run a bec as didn't want to chop wires as my summit is still under warranty
    Central Texas
    18
    I did not run a bec. Just plugged it in. I had to reverse the servo after installation which is easy.
    75
    But the Savox SC-1258TG doesn't have that much torque does it? and i've seen a few people use those.
    19
    The 1256tg is stronger. I use it on all my trucks and buggy an truggy
    Sent from my iPhone 5 using tapatalk
    Central Texas
    18
    Like Jimmy said..."stay within 300-350 oz torque" and it will be much better than stock. I run mudslingers that have 18oz of weight added to each front wheel. I just like climbing in the rocks. The stock servos just could not handle the load when faced with extreme conditions. The 35a, hd servo saver spring, all with stock linkage worked very well.
    Argentina
    67
    Quote Originally Posted by Finisher View Post
    Do you use single or dual 1256gt in the summit?
    Summit, dewalt 12v, 18/68 gear, T-bone skids
    12,314
    93
    will you guys please share with me how you adjust your HD servo saver when installing? is everyone doing the washer mod? My Savox 1230 gets here today! Pretty excited!!
    19
    I used single, however I ran an aftermarket servo saver setup. I also ran my steering servo from a life pack
    Central Texas
    18
    I did not use the washer, just the HD spring and there's really no adjustment. Just tighten it down. I would recommend using locktite on the screws to keep them from backing out.
    Victoria B.C Canada
    5,472
    I used the hi end "silver coloured"washer In mine.
    The bling factor alone...j/k lol
    You may need to try a couple different ones.i found one that fit pretty close.
    It is just acting as a spacer so to speak
    Sent using lipo power
    Mountains cant stop me
    they have tried
    93
    nice maybe I can get some one to custom make me an aluminum or titanium washer
    75
    anyone got a link to a washer that would be suitable as I don't have the kit to grind one down etc.
    Central Texas
    18
    Take your servo saver spring to your local hardware store and try and match a common flat washer with the diameter of the big end of the spring. slightly smaller will be okay just make sure it doesn't go up in the spring. Get a cadium plated or other coating so it doesn't rust.
    93
    Quote Originally Posted by oldjeeper View Post
    thanks. so why use the washer? I've seen a lot of people talking about them but I haven't come across why yet. Does it make the spring stiffer?
    Central Texas
    18
    Yes, it just takes up space in the spring seat causing it to be tighter.
    Central Texas
    18
    I elected not to use a washer. I think it might lessen your chance of breaking something in case of a hard impact. With the stronger servo, it eliminated my lack of steering power. That's just my opinion...the are many who do use a washer with no problems. It is your call...
    Victoria B.C Canada
    5,472
    I was running big tires rock crushers
    Hi torque servo was flexing the spring too easy.it will still give on bigger hits but will turn even under some load.
    Try it without first and see, may not need it.
    they have tried
    93
    ahhhh! it's here!!!
    Victoria B.C Canada
    5,472
    Also the heavy duty spring is already installed,but a back up part is never a bad thing.
    they have tried
    93
    you mean it's like that stock with the heavy spring?
    Victoria B.C Canada
    5,472
    Yes sir, it is.That was my first thought back when I went single servo.stiffer spring?
    For me (How i use my truck)it seemed logical to make the saver stiffer.I just dbl'd the stock power.i wanted the wheels to turn when I needed them to
    Why I went to hi torque in the first place.
    I do want some saver action still, though
    Just takes a little more to activate it.
    they have tried
    105
    I just kind of find it hard to believe that no one has an advertised 300-350 oz waterproof servo out there. I mean, with as big as the whole crawler thing is and all. I still plan on fordging streams etc, so waterproof is a must.
    12,314
    Probably because it is so easy to waterproof it yourself.
    419
    Advertising a servo as waterproof could be a warranty nightmare for the manf...a flawed o ring or seal and their replacing a $75+ servo due to water damage because somebody thinks their truck is a submarine.
    Like said a little handy work and you can make nearly any servo you want waterproof.
